Function: RedactTextWithConsistentAlias
The RedactTextWithConsistentAlias function is a redaction function that can be used in calculated field expressions.
RedactTextWithConsistentAlias replaces original text in a field value with a random pattern of alphanumeric characters.
This function also ensures that all instances of a field value are replaced consistently across the entire report.
For instance, if you have an Account Number AC 123446 occurring 5 times within a report, using this method will replace all occurrences of AC 123446 with X3y981043. This will allow you to aggregate or summarize on X3y981043 and get the correct results.
This function produces redaction results equivalent to Consistent alias text in Input Field Properties Window.
RedactTextWithConsistentAlias(text)
Arguments
Text may be any field of type text containing numbers.
Return value
This function returns random digits for a given field value.
Calculated field example
If you have a field named Account Number with the following values:
AC 123456
AC 333456
AC 333456
AC 123456
AC 123444
Using the function RedactTextWithConsistentAlias([Account Number]) will produce the following result:
X3y98104x
UVn876v43
UVn876v43
X3y98104x
TvRA1D4F4
