Function: RadiansToDegrees
Converts the value of an angle expressed in radians to its equivalent value in degrees.
RadiansToDegrees(angle)
Arguments
angle is any number representing an angle value expressed in radians.
Return value
This function returns a value in degrees.
Calculated field example
To convert the value 3.14159 rad, use the calculated field:  RadiansToDegrees(3.14159).
The function returns: 180°
© 2025 Altair Engineering Inc. All Rights Reserved.
