Function: PSplit
Reads a string as a postal code and splits it into 3 parts (City, State and Zipcode), then returns the specified substring.
Use this function to work with the Postal Codes within an Address Block.
PSplit(string,n)
Arguments
string is the address line.
n specifies which substring you want the function to return.
Return value
This function returns a character string.
Calculated field example
If the Postal field contained the value Boston, MA 02145, the following calculated field expression would return 02145: PSplit(Postal,3)
Filter/Find example
Records with a Postal field value of Boston, MA 02145 or Fitchburg, MA 01453 can be selected or found using the expression: PSplit(Postal,2)="MA"
© 2025 Altair Engineering Inc. All Rights Reserved.
