Function: PDFInfo
This function returns information about the table's source PDF document. Information may be:
  • Author
    The name of the person who created the document.
  • CreationDateRaw
    The date and time when the document was created, using the original PDF date format.
  • CreationDateISO
    The date and time when the document was created, in ISO 8601 date format.
  • Creator
    The name of the application that created the original document from which it was converted, if the document was converted to PDF from another format.
  • Keywords
    Keywords defined for the document.
  • ModDateRaw
    The date and time the document was most recently modified, using the original PDF date format.
  • ModDateISO
    The date and time the document was most recently modified, in ISO 8601 date format.
  • PageCount
    The total number of pages in the document.
  • Producer
    The name of the application that converted it to PDF, if the document was converted to PDF from another format.
  • Subject
    The subject of the document.
  • Title
    The document’s title.
  • Version
    The PDF version of the document.
You can use this feature to verify and audit the data you have brought into Data Prep Studio.
PDFInfo("infotype")
Arguments
infotype may be:
  • Author
  • CreationDateRaw
  • CreationDateISO
  • Creator
  • Keywords
  • ModDateRaw
  • ModDateISO
  • PageCount
  • Producer
  • Subject
  • Title
  • Version
Note:
  • infotype must be enclosed in quotes, e.g. "Version"
Return value
This function returns a string value corresponding to the information retrieved from the PDF file.
Notes:
  • If the information is not available in the PDF document, the function returns a blank.
  • If the function is applied to a non-PDF document, the function returns a blank
Calculated field example
Define a calculated field PDF_Creator using the following expression: PDFInfo("Creator")
If the original document was created from PostScript, for example, the result is a  PDF_Creator column with the value: PScript5.dll Version 5.2.2
© 2025 Altair Engineering Inc. All Rights Reserved.
