Function: Lower
Converts all uppercase letters in a string to lowercase letters.
Lower(string)
Arguments
string can be a constant, a character field, an expression that results in a string or a function that returns a string.
Return value
This function returns a character string.
Calculated field example
If the Billing field contained the value Monthly, the following calculated field expression would return monthly: Lower(Billing)
Filter/Find example
All filter expressions are case insensitive, so Lower has no practical application. For find expressions, use the Match Case setting to determine case sensitivity.
© 2025 Altair Engineering Inc. All Rights Reserved.
