Function: Left
Extracts n number of characters from the beginning of a string.
Left(string,n)
Arguments
string can be a constant, a character field, an expression that results in a string or a function that returns a string.
n is the length of the substring you want to extract. The length can be a constant, a numeric field, an expression that results in a number or a function that returns a number.
Return value
This function returns a character string.
Calculated field example
If the Company field contained the value Widgets Inc, the following calculated field expression would return Widgets: Left(Company,7)
Filter/Find example
Records with a Company field value of Wright Corp or Wright Brothers can be selected or found using the expression: Left(Company,6)="Wright"
© 2025 Altair Engineering Inc. All Rights Reserved.
