Function: FiscalDayOfYear
Returns the day number within the fiscal year in which the given date falls.
FiscalDayOfYear(date)
Arguments
Date may be any valid date in the range 1/1/1601-12/31/2400.
Return Value
This function returns a number.
Calculated field example
The following expression will return 45 from a Ship Date field containing 2/14/2008: FiscalDayOfYear([Ship Date])
Filter/find example
Orders shipped in the first month of 2008 could be found with the following expression: FiscalDayOfYear([Ship Date])<32
Note: The example above assumes that the following time intervals settings have been specified via the Time Intervals wizard:
The fiscal year consists of 12 calendar months starting on January 1.
The fiscal week is defined as the first week of the year that starts on January 1, regardless of what day of the week it is.
The calendar week is defined as the first week of the year that starts on January 1, regardless of what day of the week it is.
