Function: Base64 Decode
Decodes any string encoded using the Base64 encoding scheme.
Base64Decode(string)
Arguments
string is a base64-encoded string, or the name of a Field containing Base64-encoded values.
Return value
decoded value
Calculated field example
Calculated Field:
Base64Decode([Item Description Encoded])
If Item Description Encoded value is: Uk9BRC00NTAgUkVELCA1OA==
The function returns the following: ROAD-450 RED, 58
