Function: Asc
The Asc function returns the numeric value of a character.
Note: If you pass a string of more than one character to this function, the function will return the value of only the first character of the string.
Asc(string)
Arguments
String can be a constant, a character field, or an expression that results in a single character or a function that returns a single character.
Return value
This function returns a number in the range 0-255.
Calculated field example
If the Amount field contains the values 876.00 and  ¥1022 (indicating an amount in Japanese yen), the following calculated field expression would return the string Dollars or Yen: If(Asc(Amount)=165,"Yen","Dollars").
The first part of this expression, If(Asc(Amount)=165, determines whether or not the Yen symbol (character code 165) appears at the beginning of the Amount field. If it does, the first value, Yen, is returned; otherwise the second value, Dollars, is returned.
Filter/Find example
Records with an Amount field value beginning with the Japanese yen symbol ( ¥ ) can be selected or found using the expression: Asc(Amount)=165.
© 2025 Altair Engineering Inc. All Rights Reserved.
