Exporting the Change History List
When working with reports generated at regular intervals, such as sales totals compiled at the end of every month, you may wish to apply the changes you made to the January report to the February report. Data Prep Studio allows you to export the Change History list created for one table so that you can import the changes to another workspace and apply them to a similar table.
Do one of the following:
Select Export Change List from the application menu.
from the menu bar at the top of the Change History panel.
In the Save As dialog that displays, specify the path to the folder in which you want to store the exported change list.
Enter a name for the change history file in the appropriate field.
Select Save.
The change history list is exported to a file with a .dpcl extension.
