Export Properties: Altair Knowledge Studio
The table below describes the properties that can be specified for exports to Altair Knowledge Studio.
Property
Table The name of the selected table to be exported.
Export Type The file type to which your export will be saved.
Export Location
This setting describes where the export file will be saved and what its name will be. Enter the path and name of the export file. You can embed macros (of the form &[macro]) in the file name.
Filter
This setting specifies what filter to apply to the table when it is exported.
When All Filters is selected as a filter option, exports will automatically be named according to the file name.
Sort
This setting specifies what sort to apply to the table when it is exported.
When File Exists
This setting specifies what Data Prep Studio should do if a file with the same name exists in the folder you specified in the Export As field. Select an action if the export file already exists:
  • Overwrite the file
  • Skip the export operation
Export All Rows/Limited Rows For tables with defined row limits, this setting specifies whether the defined row limits should be respected during export. Select the appropriate checkbox to instruct Data Prep Studio to export all rows or only those rows that fall within the limit you have set.
© 2025 Altair Engineering Inc. All Rights Reserved.
