Deleting Columns
DELETING A SINGLE COLUMN
  1. On the Templates panel, select the template containing the column you want to delete.
  2. Select the delete icon to beside the column you want to delete..
DELETING MULTIPLE COLUMNS
  1. On the Worksheet display, select the column values you want to display. Use Shift+Left Click to select more than one column.
  2. Do one of the following:
  • Select Delete Columns on the toolbar
  • Select Delete Columns from the context menu.
© 2025 Altair Engineering Inc. All Rights Reserved.
