Connector Dialog for OData - Limitations
The following are known limitations (and some workarounds) for this release:
Limitation: For expanded collections, if the Navigation Property's entity type has a base type, the connector can not retrieve the columns or properties of that navigation property. Thus, it will only display the fields from the base collection.
Example:
Collection URL: https://services.odata.org/V3/OData/OData.svc
Base Collection: Advertisements
Navigation Property: FeaturedProduct
Based on the metadata, the Base Type of FeaturedProduct is Product\
Limitation: In some cases, if you select an expanded collection, query parameters are not saved or displayed in Connector form but the OData Query URL is still valid.
Collection URL: https://services.odata.org/TripPinRESTierService/
Collection: People_Friends
Query Parameter: UserName StartsWith Russell
  1. Connect to OData with the details above then click on OK
  2. Click on Edit Table Info.
Notice that the values in Query Parameters are not saved but the OData Query URL is still valid with the query parameter values.
Limitation: Enabling/Disabling Supports Metadata option applies to old versions of OData with XML format only.
Limitation: Function Import can be queried but with additional steps.
Limitation: The OData Connector currently supports OData v1 to v4. The Simple.OData.Client library used supports OData versions 1 to 4 as stated here.
© 2025 Altair Engineering Inc. All Rights Reserved.
