Connector Dialog for Google Analytics
IMPORTANT: The Google Analytics connector is compatible with Google Analytics version 4.0. If the site you wish to access has not been migrated from Universal Analytics, this site will be inaccessible to the connector.
Workspaces containing connections to an earlier version of Google Analytics can still be loaded into the application. However, some properties may have to be manually modified to successfully open data sources using the new connector.
General Instructions
  1. Launch the Connect to Data dialog and then select Application > Google Analytics.
    The Google Analytics connector dialog displays.
  2. Provide the following information:
    • Key File Path
    • Property ID
  3. Enter the date range to use to filter rows.
  4. Click Fetch Dimensions and Metrics.
    The Categories, Dimensions and Metrics list boxes are populated. Note that some date/time data imports from Google Analytics may display differently in Data Prep Studio. For example, average time values (under Metrics), such as Avg. Session Duration and Avg. Time on page, display in Google Analytics in HH:MM:SS format but display in Data Prep Studio in SS (seconds) format . You can use the date/time formatting options of Data Prep Studio to format the necessary fields after import these data into the application.
  5. Double-click on any field from these list boxes. They are selected and displayed in the Selected Columns list.
  6. Click X to delete a selected column in the list.
  7. Click OK to confirm the selection and retrieve the record set into Data Prep Studio.
The Google Analytics connector dialog includes the following fields and settings:
Field
Authentication Method
Determines the authentication method to be used during the course of the session.
Select the method to use from the drop-down provided:
  • Service Account
  • OAuth 2.0
Required connection fields (in bold) will depend on the authentication method you select.
Property ID
The identifier associated with your account and used by Google Analytics to collect data.
This ID a numeric in value. If your property ID is alphanumeric, you must get a new one from the GA migrated site.
For Authentication Method: Service Account
Key File Path
Location of the key file furnished by Google Analytics when you created the Service Account. You can also click Browse to select the path of the key file.
Notes:
The key file must be in the JSON format.
When opening an old workspace containing a Google Analytics connection that uses a keyfile in p12 format, you must generate a new keyfile in JSON format.
For Authentication Method: OAuth 2.0
Client ID
Enter the client ID key for your application when authenticating to REST endpoints with OAuth 2.0 enabled (AuthenticationMethod=OAuth2).
Client Secret
Enter the client secret for your application when authenticating to REST endpoints with OAuth 2.0 enabled.
Important: The client secret is a confidential value used to authenticate the application to the service. To prevent unauthorized access, this value must be securely maintained.
Reset Connection
Check this box to reset the OAuath connection and fetch new access tokens.
Common Fields
Date From/To
Select the date range that will be used to filter the Google Analytics rows.
Note that the start date selected must be later than August 13, 2015.
Fetch Dimension and Metrics
Click to select the Dimensions and  Metrics valid for the Google Account you have specified.
This populates the Categories, Dimensions and Metrics list boxes.
Categories
Click to navigate and select a Google Analytics Category.
Dimensions
Double click to select a Google Analytics Dimension.
Metrics
Double-click to select a Metric.
Selected Columns
Displays the columns that have been fetched.
Clear Fields Removes the selected columns.
Validate Selection
Validate the Dimensions and Metrics you have selected.
Preview Data
Click to fetch data using the credentials and criteria you have specified. 10 records are displayed to allow you to verify that you are selecting the correct data.
OK/CANCEL
Select OK to establish the connection and fetch data or Cancel to close the dialog.
The state of the OK and PREVIEW buttons provide a handy status about the state of your connection:
  • The OK and PREVIEW DATA buttons are enabled as soon as the required fields have been entered and verified. This usually means a connection to the data source has been established and a table has been selected.
  • The OK button is disabled when an update is made that can lead to an invalid result (e.g. the User Name or Password is not valid, or the the SQL statement in the Query tab is invalid). In such cases, use  PREVIEW DATA to validate that data can be retrieved. If this fails verify your connection information or query until data can be retrieved.
Notes:
  • You cannot select more than 7 dimensions and 10 metrics per request.
  • Some dimension and metric combinations do not work together. At present, no list of compatible combinations is available.
  • Selecting any dimension/metric will disable non-compatible dimensions/metrics.
  • If the metrics and dimensions selected are deprecated, they must be removed and new fields must be selected from the appropriate lists.
  • BetaDataAnalyticsClient limits: Default = 10,000; Maximum = 250,000
© 2025 Altair Engineering Inc. All Rights Reserved.
