Connector Dialog for Active Directory
The Active Directory connector dialog includes the following fields and settings:
Field |
Description |
Server Name |
The name of the Server to connect to. This name must be prefixed by: LDAP:// |
User ID |
A valid User ID required to log-on to the data source. |
Password |
A valid Password required to log-on to the data source. This password must match the User ID above. |
Base DN |
The base portion of the distinguished name, used for limiting results to specific subtrees. |
Tables |
Select the table you want to view from the drop-down. |
Filter |
Enter required criteria as needed. Refer to this article for more information. |
Validate Connection |
Click to check that the connection information you have entered is correct. An error message will display if validation is not successful. Otherwise the message Validation Successful is displayed. |
Preview Data |
Click to fetch data using the credentials and criteria you have specified. This allows you to confirm your connection, ensure you have connected to the correct table, check your query, and verify the information that will be loaded. Notes:
OK/CANCEL |
Select OK to establish the connection and fetch data or Cancel to close the dialog. The state of the OK and PREVIEW buttons provides a handy status about the state of your connection:
