Applying Changes to a Different Column
Data Prep Studio allows you to "reuse" changes that you have already made in conjunction with the Change History list.
To do so, drag a change from the Change History list to another column in your table. This column must have the same data type as the column to which the change was initially applied.
The change is applied to the new column and a new entry is added to the Change History list.
