Specific Heat
The specific heat content for a material is the amount of energy it takes to raise one unit of mass (i.e. kg) of that material by one degree (i.e. Kelvin). It is also the derivative with respect to temperature of the Specific Enthalpy for the material. For 2024.1 the Specific Heat can be imported, and exported as a table for injection molding applications, and a plot generated for visualization. The specific enthalpy can be imported and a plot generated for visualization, but the fitting of the Specific Enthalpy has not yet been implemented.
Follow these steps to set up and review specific heat values:
- Verify the File Type option before importing a file.
- On the Material Overview tab, click the Specific Heat button and select the file containing the material test data.
Alternatively, set the Sel selection box on the Material Overview tab to take a scalar value, and then enter that value in the field before clicking the button. The scalar value will then be transferred to the Specific Heat tab for approval.
You can also import Specific Enthalpy, and a plot will be generated.Note: This release does not compute the slopes, which represent the specific heat values.
- Select the Specific Heat (Cp) capacity Model value
from the list box. For this initial release this will be a scalar value.
- Examine the table of specific heat values. For semi-crystalline materials, expect to see a characteristic spike in the data near the phase transition. This spike is due to the fact that the specific heat capacity is the slope of the specific enthalpy with respect to temperature.
- Identify or estimate a nominal value for specific heat; analytically, this is done by integrating and averaging across the temperature range to give a "path-averaged-value." One can estimate an average value by inspecting the table (e.g., between 2873 and 3528 J/kg·K).
Figure 1. Specific Heat Value
- Enter the selected Specific Heat Value (Nominal) value (e.g., 3528 J/kg·K).
- Click Approve Model Fit to finalize the setting and approve the model fit for export to a simulation file.
