The Specific Volume (pvT) supported material models for Material Modeler are
described here. These models describe the behavior of a single cooling rate.
Dual Domain Tait
Thermodynamic Parameters: Equations of state are often written using
parameters for pressure , volume , and temperature , which relate to universal constants.
van der Waals Equation: The vander Waals equation improves the ideal gas law.
However, it cannot adequately describe the complex interactions present in real
fluids, such as non-Newtonian polymer melts.
Tait Empirical PVT Relation: Developed in 1888, the Tait empirical PVT
(Pressure-Volume-Temperature) relation can accurately reproduce experimental liquid
densities for polymers in both melt and glassy states. The equation, as it is used
for injection molding simulation software, is as follows:
Where:
is the specific volume at temperature and pressure .
is the specific volume at a reference state.
is a constant.
is a temperature-dependent function.
accounts for additional volume changes due to temperature and
pressure.
Tait Equation - Solid and Liquid Domains
Figure 1. Specific Volume vs Temperature
Note: Plot of specific volume versus temperature and pressure
for a semicrystalline polymer.
Solid Domain: The data fit coefficients are:
Molten Domain: The data fit coefficients are:
Understanding the following distinctions and the role of the B7 parameter is
important for accurately fitting specific volume data.
The Tait model describes the behavior of specific volume in different phases of
materials, specifically for semi-crystalline and amorphous polymers. When applying
this model, we consider different domains and parameters to capture the material's
characteristics accurately.
Morphological Types
Semi-crystalline Materials observe distinct behaviors in both solid and liquid
domains. These materials transition between phases, and this transition can be
described using the Tait equation parameters.
Figure 2. Semi-crystalline Materials
Amorphous Materials exhibit a different behavior compared to semi-crystalline
ones. The key difference lies in the B7 parameter, which helps to describe the
specific volume behavior in the amorphous state. For purely amorphous materials, the
B7 parameter is zero, resulting in two linear segments that meet at a transition
point.Figure 3. Amorphous Materials
Hybrid Morphology Some materials exhibit hybrid morphology, which combines
characteristics of both amorphous and semi-crystalline materials. These materials
present a non-trivial curvature in their specific volume data, which cannot be
described by a zero B7 parameter. Instead, the B7 parameter takes on a real value to
accurately represent this curvature.Figure 4. Hybrid Morphology
Other Morphologies Some materials exhibit volumetric behavior different than
the three described above. Polyetherimide (PEI) and several polymer alloys exhibit a
volume reduction as temperature increases when the pressure is well above one
atmosphere. Their curves would seem to change their morphological behavior as the
pressure increases. Because the molecules are large, and especially in the case of
polymer alloys, when the temperature increases, the ability of the molecules to mix
increases (i.e. they become more miscible). This results in a volume reduction
similar to, but more exaggerated than the often used example of mixing ethanol and
water in equal volume amounts (50ml of water + 50 ml of ethanol → 96-97ml of
mixture, not 100ml. These morphologies are not yet supported by Material Modeler's
automated Specific Volume Fitter. Figure 5. Specific Volume Plot for PEI
Dual Domain
IKV
Equations for Specific Volume:
Figure 6. Specific Volume in SI Units from IKV Parameters
Molten:
Solid:
Parameters:
Note: Operates directly on Temperature, not . Temperature units are fixed to those from fitting.
Schmidt and IKV
Differ only by arrangement of variables
Equations operate directly on temperature
Material Modeler assumes cgs units for IKV, and SI for Schmidt.
Modified Schmidt
Uses the Schmidt arrangement of variables.
Operates on (T - T0), not directly on the temperature value.
Units can be converted for this model.
Renner: Continuous Model
Renner with Crystallization:
Continuous model with crystallization fraction as an input
Wang Polynomial:
Includes cooling rate
18 Parameters.
Dual Domain
Schmidt
Equations of State:
Molten:
Solid:
Parameters:
Important Note:
Parameters for pressure dependence are fixed to those from fitting
because of the way temperature is managed.
Dual Domain Modified
Schmidt
Because this model operates on the difference of the temperature to its transition
temperature, the parameters in this model can be converted to any consistent unit
system.
