Project Folder
Define your project purpose using the Objective list and Pick Project Folder. The purpose automatically configures the Material Test File List metadata and its values, which defines the required and the optional data for fitting.
All files from the application will be saved in this folder, with file names determined by the material name and type of information stored.
After installation, the default project root folder is defined in the preferences and utilized as the initial project folder. The installer checks for the essential data, solvers, and other applications. Compose is required for Material Modeler, while HyperWorks Solvers are optional but offer additional functionality for Elastoplastic and Polymer applications.
