Fitting Data
Involves adjusting specific parameters to closely match the observed data with the model.
If the input file contains test data, the data is automatically fit and then passed to the Specific Volume pvT tab displaying the specific volume model parameter values and a plot of the data, if available, along with the curves of the fit.
Fitting Data to the Tait Equation
The Tait equation is a mathematical model used to describe the volumetric behavior of polymer materials under pressure and temperature changes. While it can be used for other materials, this is uncommon at this time.
- Adjust b3m & b4m to align the molten data across all pressures tightly with the model.
- Adjust b8 to achieve an exact fit to the p0 curve.
- Adjust b9 to make sure the computed data at 200 MPa is less than the solid data at 200 MPa and that it converges at the transition temperature (Ttr).
- Adjust b3s & b4s to do final adjustments for improving the fit of
the solid data.
There is a significant spike around the 250-260 range on the x-axis, which likely corresponds to a critical point or transition region, potentially the Ttr.
This detailed process ensures the Tait Equation model is accurately fitted to the observed data, capturing both molten and solid states effectively.Figure 2. Displaying Molten and Solid State Values
- Click Save Changes to save the edits.
If changes don't work out, use the Equation of State (pvT) Model selection box and re-select the same model to return to the last saved coefficients.
