File Load and Save
Files load and save are saved as a variable called PDSmat. The file stores all your material data and test results.
- is a structured variable that contains all essential project details. The .pds file extension is used to save and load your work.
- includes fitted coefficients and is saved as a single MATLAB 7.3 formatted file
with the extension, ".pdsmat", or can be exported via the AMDC Objective option as a .json
file.Note: Save your work especially after setting objectives or making significant property value adjustments.
