Approve Specific Volume pvT Model
Adjust the units and default values for different parameters. Once satisfied with the data for specific volume model parameters approve the model fit data. If a model other than Tait is active when approved, that model will be used for mechanical fitting. Altair's injection molding applications only support the Tait model at this time, so the Tait model would still be used for export.
  1. Verify the Quality Check reports.
  2. Select the Approve Model Fit checkbox, and click Save Changes to save the customised parameter values.
Figure 1. Approve Model Fit Data
Note: After approval, the Material General Information panel becomes inactive. If all approvals are undone, the Material General Information panel becomes active and editable again.
The file name from the import of the pvT data is displayed in the field to the right of the button in the Material Overview tab, and the color of the Equation of State pvT button is auto-updated as a visual indicator. The row is made inactive to prevent accidental edits.
