Control SISOs in Inspire Motion
Define a linear, time-invariant dynamic system in the Laplace domain with a single input and output.
For information on how to add or edit an entity like a control SISO, see Entity Creation.
Control SISOs Properties in Inspire Motion
Descriptions of Control SISOs properties in the Property Editor.
| Property | Description |
| General | |
| Name | Name of the entity |
| Variable Name | The variable name, a unique identifier string of the entity |
| ID | A unique identifying integer |
| Properties | |
| Numerator | Specifies the coefficients of the numerator polynomial of the transfer function in the ascending powers of "s." |
| Denominator | Specifies the coefficients of the denominator polynomial of the transfer function in the ascending powers of "s." |
| Static Hold | Turn on this option if the state of the control SISO is not permitted to change during static and quasi-static analysis of the solver. Otherwise, turn off the option. |
| Input | Set the input to the transfer function of the controller. You can enter initial condition values and enter constant, spline, spline3D, or expression values. |
| Type |
| Use initial conditions | Turn on this option and enter an initial condition value for the control SISO. |
