Advanced Joints
Use the Advanced Joints tool to create and edit a set of special constraints called higher pair joints. Typically, these are constraints that involve a curve or surface on at least one of the two parts.
| Advanced Joint Type | Removes Translational DOF | Removes Rotational DOF | Removes Total Number of DOF |
| Point to Curve | 2 | 0 | 2 |
| Curve to Curve | 1 | 2 | 3 |
For information on how to add or edit an entity like an advanced joint, see Entity Creation.
Advanced Joints Properties
Descriptions of advanced joints properties in the Property Editor.
| Property Name | Description | ||
| General | |||
| Name | Name of the entity | ||
| Variable Name | The variable name, a unique identifier string of the entity | ||
| ID | A unique identifying integer | ||
| Type | Type of advanced joint | ||
| Part 1 | The part on which the advanced joint is applied. This is only available for PointToCurveJoint. | ||
| Origin | Location where the advanced joint is applied. This is only available for PointToCurveJoint. | ||
| Curve | Curve that defines the contour or shape on which the Origin can move. This is only available for PointToCurveJoint. | ||
| Curve 1 | The curve that defines the contour or shape on the first part. This is only available for CurveToCurveJoint. | ||
| Curve 2 | The curve that defines the contour or shape on the second part. This is only available for CurveToCurveJoint. | ||
| Reference | The reference frame (Marker) for the curve. This is only available for PointToCurveJoint. | ||
| Reference 1 | The reference frame (Marker) for the first curve. This is only available for CurveToCurveJoint. | ||
| Reference 2 | The reference frame (Marker) for the second curve. This is only available for CurveToCurveJoint. | ||
| Notes and Tags | |||
| Attachment Candidate | Add an attachment candidate tag. See Attachments. | ||
