Datasets
Datasets are container entities that can hold properties of various data types such as Real, Integer, String, Boolean, Filename, and Option.
Datasets can be used to categorize and organize various properties for a System or Analysis that are then linked to other entities.
For information on how to add or edit an entity like a dataset, see Entity Creation.
Dataset Properties
Descriptions of dataset properties in the Property Editor.
Table 1.
Property Name Description
General
Name Name of the entity
Variable Name The variable name, a unique identifier string of the entity
ID A unique identifying integer
If the field is a pair entity, separate IDs are set for the Left and Right sides.
Definition
Name Variable name of the definition the dataset is instanced of.
File Definition file name (mdl), if the definition is included through a file.
File Modified Indicates definition file is modified, but not saved.
Properties
DataMembers Click Add/Delete to open a floating dialog where you can add or delete data members.
Select the Type from the following:
  • Integer
  • Real
  • Boolean
  • String
  • Option
  • File
    • Optionally, select the Input check box for the file.
Click the + icon to add the data member to the table.
To delete a data member, select a row in the table, and then click the
Trash Can Delete Icon
icon.
Figure 1. DataMembers Add/Delete Dialog
You can edit most of the data member values in both the dialog and the Property Editor table. You can only edit the data members' Name and Label, and the values of the Option type, in the dialog. The data members are identified by their name in the below fields of the Property Editor.
[Integer Data Member] Enter an integer value.
[Real Data Member] Enter a real number value.
[Boolean Data Member] Select or deselect the check box to set the Boolean true/false value.
[Option Data Member] Select the option from the dropdown.
Note: To edit the values of the options, open the DataMembers Add/Delete dialog.
[File Data Member] Click the
Browse File
icon to browse for a file.
[Attachment] Click the attachment name to open the DataSets guide panel. To add or edit attachments, see Attachments.
Notes and Tags
Attachment Candidate Add an attachment candidate tag. See Attachments.
