/SURF/BOX/ALL or /SURF/BOX2/ALL
Block Format Keyword Describes the surfaces inside the box (include inner segments).
Only one box_ID is allowed:
| /SURF/BOX/ALL/surf_ID/unit_ID or /SURF/BOX2/ALL/surf_ID/unit_ID | |||||||||
| surf_title | |||||||||
| box_ID | |||||||||
Definition
| surf_ID | Surface
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| surf_title | Surface
| box_ID | Box identifier, which is
defined in Boxes (Integer, maximum 10 digits) |
- The format is the same as the corresponding options /SURF/type/surf_ID.
- Input format for
BOX:
- The segments built from 3-node and 4-node shells are still selected the same way as with /SURF/type/surf_ID and segments from inside of volumic parts (inner segments) will also be included.
- If type is
BOX, all segments supported by solids, shells and 3-node
shells with all nodes inside the box or on its external surface are selected
(segments lying on solid elements are not considered).
If type is BOX2, all segments with at least one node inside the box or on its surface are selected.
