Force and Moment
Linear Stiffness and Damping Behavior
The simplest formulation is a linear elastic spring stiffness, where the internal force is proportional to the relative displacement. In this case, only the constant stiffness parameter K i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbWaaS baaSqaaiaadMgaaeqaaaaa@3848@ and optional damping parameter C i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbWaaS baaSqaaiaadMgaaeqaaaaa@3848@ are entered.
For linear stiffness, the force and moment are:
  • F ( δ ) = K i δ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacqGH9aqpcaWGlbWaaSbaaSqa aiaadMgaaeqaaOGaeqiTdq2aaWbaaSqabeaacaWGPbaaaaaa@4012@
  • M ( θ ) = K i θ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGnbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaacqGH9aqpcaWGlbWaaSbaaSqa aiaadMgaaeqaaOGaeqiUde3aaWbaaSqabeaacaWGPbaaaaaa@403B@
For linear dashpot, the force and moment are:
  • F ( δ ) = C i δ ˙ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacqGH9aqpcaWGdbWaaSbaaSqa aiaadMgaaeqaaOGafqiTdqMbaiaadaahaaWcbeqaaiaadMgaaaaaaa@4013@
  • M ( θ ) = C i θ ˙ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGnbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaacqGH9aqpcaWGdbWaaSbaaSqa aiaadMgaaeqaaOGafqiUdeNbaiaadaahaaWcbeqaaiaadMgaaaaaaa@403C@
For linear stiffness and dashpot, the force and moment are:
  • F ( δ ) = K i δ i + C i δ ˙ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacqGH9aqpcaWGlbWaaSbaaSqa aiaadMgaaeqaaOGaeqiTdq2aaWbaaSqabeaacaWGPbaaaOGaey4kaS Iaam4qamaaBaaaleaacaWGPbaabeaakiqbes7aKzaacaWaaWbaaSqa beaacaWGPbaaaaaa@45B3@
  • M ( θ ) = K i θ i + C i θ ˙ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGnbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaacqGH9aqpcaWGlbWaaSbaaSqa aiaadMgaaeqaaOGaeqiUde3aaWbaaSqabeaacaWGPbaaaOGaey4kaS Iaam4qamaaBaaaleaacaWGPbaabeaakiqbeI7aXzaacaWaaWbaaSqa beaacaWGPbaaaaaa@45ED@
Nonlinear Behavior
The force and moment in a spring is computed as:
F i ( δ i ) = f ( δ i A s c a l e i ) [ A i + B i ln ( max ( 1 , | δ ˙ i D i | ) ) + E i g ( δ ˙ i F i ) ] + C i δ ˙ i + H s c a l e i h ( δ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakqaabeqaaiGacA eadaWgaaWcbaGaamyAaaqabaGcdaqadaqaaiabes7aKnaaCaaaleqa baGaamyAaaaaaOGaayjkaiaawMcaaiabg2da9iGacAgadaqadaqaam aalaaabaGaeqiTdq2aaWbaaSqabeaacaWGPbaaaaGcbaGaamyqaiaa dohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaadMgaaeqaaa aaaOGaayjkaiaawMcaamaadmaabaGaamyqamaaBaaaleaacaWGPbaa beaakiabgUcaRiaadkeadaWgaaWcbaGaamyAaaqabaGcciGGSbGaai OBamaabmaabaGaciyBaiaacggacaGG4bWaaeWaaeaacaaIXaGaaiil amaaemaabaWaaSaaaeaacuaH0oazgaGaamaaCaaaleqabaGaamyAaa aaaOqaaiaadseadaWgaaWcbaGaamyAaaqabaaaaaGccaGLhWUaayjc SdaacaGLOaGaayzkaaaacaGLOaGaayzkaaGaey4kaSIaamyramaaBa aaleaacaWGPbaabeaakiGacEgadaqadaqaamaalaaabaGafqiTdqMb aiaadaahaaWcbeqaaiaadMgaaaaakeaacaWGgbWaaSbaaSqaaiaadM gaaeqaaaaaaOGaayjkaiaawMcaaaGaay5waiaaw2faaaqaaiaaywW7 cqGHRaWkcaaMe8Uaam4qamaaBaaaleaacaWGPbaabeaakiqbes7aKz aacaWaaWbaaSqabeaacaWGPbaaaOGaey4kaSIaamisaiaadohacaWG JbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaadMgaaeqaaOGaciiAam aabmaabaWaaSaaaeaacuaH0oazgaGaamaaCaaaleqabaGaamyAaaaa aOqaaiaadAeadaWgaaWcbaGaamyAaaqabaaaaaGccaGLOaGaayzkaa aaaaa@82E9@
Where, i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@374C@ is the translational degrees of freedom: 1,2,3
M i ( θ i ) = f ( θ i A s c a l e i ) [ A i + B i ln ( max ( 1 , | θ ˙ i D i | ) ) + E i g ( θ ˙ i F i ) ] + C i θ ˙ i + H s c a l e i h ( θ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakqaabeqaaiGac2 eadaWgaaWcbaGaamyAaaqabaGcdaqadaqaaiabeI7aXnaaCaaaleqa baGaamyAaaaaaOGaayjkaiaawMcaaiabg2da9iGacAgadaqadaqaam aalaaabaGaeqiUde3aaWbaaSqabeaacaWGPbaaaaGcbaGaamyqaiaa dohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaadMgaaeqaaa aaaOGaayjkaiaawMcaamaadmaabaGaamyqamaaBaaaleaacaWGPbaa beaakiabgUcaRiaadkeadaWgaaWcbaGaamyAaaqabaGcciGGSbGaai OBamaabmaabaGaciyBaiaacggacaGG4bWaaeWaaeaacaaIXaGaaiil amaaemaabaWaaSaaaeaacuaH4oqCgaGaamaaCaaaleqabaGaamyAaa aaaOqaaiaadseadaWgaaWcbaGaamyAaaqabaaaaaGccaGLhWUaayjc SdaacaGLOaGaayzkaaaacaGLOaGaayzkaaGaey4kaSIaamyramaaBa aaleaacaWGPbaabeaakiGacEgadaqadaqaamaalaaabaGafqiUdeNb aiaadaahaaWcbeqaaiaadMgaaaaakeaacaWGgbWaaSbaaSqaaiaadM gaaeqaaaaaaOGaayjkaiaawMcaaaGaay5waiaaw2faaaqaaiaaywW7 cqGHRaWkcaaMb8UaaGjbVlaadoeadaWgaaWcbaGaamyAaaqabaGccu aH4oqCgaGaamaaCaaaleqabaGaamyAaaaakiabgUcaRiaadIeacaWG ZbGaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGPbaabeaaki GacIgadaqadaqaamaalaaabaGafqiUdeNbaiaadaahaaWcbeqaaiaa dMgaaaaakeaacaWGgbWaaSbaaSqaaiaadMgaaeqaaaaaaOGaayjkai aawMcaaaaaaa@84E0@
Where, i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@374C@ is the rotational degrees of freedom: 4,5,6
The variables in the force and moment equation represent:
f ( δ i A s c a l e i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaadaWcaaqaaiabes7aKnaaCaaaleqabaGaamyAaaaaaOqaaiaa dgeacaWGZbGaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGPb aabeaaaaaakiaawIcacaGLPaaaaaa@4238@ Spring force versus displacement function input as fct_ID1i
f ( θ i A s c a l e i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaadaWcaaqaaiabeI7aXnaaCaaaleqabaGaamyAaaaaaOqaaiaa dgeacaWGZbGaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGPb aabeaaaaaakiaawIcacaGLPaaaaaa@4249@ Spring force versus rotation function input as fct_ID1i.
A i B i D i E i  and  F i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9 pgeaYRXxe9vr0=vr0=vqpWqaaiaaciWacmaadaGabiaaeaGaauaaaO qaaiaadgeadaWgaaWcbaGaamyAaaqabaGccaqGSaGaaeiiaiaadkea daWgaaWcbaGaamyAaaqabaGccaqGSaGaaeiiaiaadseadaWgaaWcba GaamyAaaqabaGccaqGSaGaaeiiaiaadweadaWgaaWcbaGaamyAaaqa baGccaqGGaGaaeyyaiaab6gacaqGKbGaaeiiaiaadAeadaWgaaWcba GaamyAaaqabaaaaa@4ACC@ Scaling coefficients
ln ( max ( 1 , | δ ˙ i D i | ) ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGSbGaai OBamaabmaabaGaciyBaiaacggacaGG4bWaaeWaaeaacaaIXaGaaiil amaaemaabaWaaSaaaeaacuaH0oazgaGaamaaCaaaleqabaGaamyAaa aaaOqaaiaadseadaWgaaWcbaGaamyAaaqabaaaaaGccaGLhWUaayjc SdaacaGLOaGaayzkaaaacaGLOaGaayzkaaaaaa@4785@ Logarithmic function that scales the spring stiffness as the velocity increases
Figure 3. With Parameter Input
g ( δ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbWaae WaaeaadaWcaaqaaiqbes7aKzaacaWaaWbaaSqabeaacaWGPbaaaaGc baGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIcacaGLPaaaaa a@3DA6@ Scale the stiffness as a function of linear input as fct_ID2i
g ( θ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbWaae WaaeaadaWcaaqaaiqbeI7aXzaacaWaaWbaaSqabeaacaWGPbaaaaGc baGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIcacaGLPaaaaa a@3DB7@ Scale the moment as a function of rotational velocity input as fct_ID2i
This input can be used to model nonlinear strain rate effects of the spring stiffness.
Figure 4. With g Function Input
C i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbWaaS baaSqaaiaadMgaaeqaaaaa@3840@ Linear damping coefficient used to increase the spring stiffness as a function of velocity
h ( δ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGObWaae WaaeaadaWcaaqaaiqbes7aKzaacaWaaWbaaSqabeaacaWGPbaaaaGc baGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIcacaGLPaaaaa a@3DA7@ or h ( θ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGObWaae WaaeaadaWcaaqaaiqbeI7aXzaacaWaaWbaaSqabeaacaWGPbaaaaGc baGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIcacaGLPaaaaa a@3DB8@ Nonlinear damping function input as fct_ID4i
Linear or nonlinear damping as a function of velocity can also be added to the spring force using either a linear damping coefficient or a user-defined function.
Figure 5. With h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374B@ Function Input
The functions g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374B@ and h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374B@ both describe the damping behavior of the spring. However, the g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374B@ function scales the spring stiffness function f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374B@ , but the h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374B@ function adds to the spring stiffness function f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374B@ .
