/SENSOR/PYTHON
Block Format Keyword Describes a sensor defined Python script and used to activate or deactivate an object.
/SENSOR/PYTHON/sens_ID
def function_name(argument)
…Python code…
return variable
Blank line after the “return” is mandatory
Blank line
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
function_name Function name. Must be unique in the model.
(Text)
argument (Mandatory) Argument of the function.
(Text)
variable (Mandatory) Output variable.
(Text)
Radioss Variables
The Python script can use global, nodal, elementary or other sensors data from Radioss.
Table 1. Global Variables
key Definition
TIME Current simulation time.
DT Current time step.
Table 2. Nodal Variables
key Definition
Ci(node_ID) Coordinate i ∈ X , Y , Z MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfaaiaawUha caGL9baaaaa@3E94@ of node_ID in the global coordinate system.
Di(node_ID) Displacement i ∈ X , Y , Z MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfaaiaawUha caGL9baaaaa@3E94@ of node_ID in the global coordinate system.
Vi(node_ID) Translational velocity i ∈ X , Y , Z MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfaaiaawUha caGL9baaaaa@3E94@ of node_ID in the global coordinate system.
Ai(node_ID) Translational acceleration i ∈ X , Y , Z MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfaaiaawUha caGL9baaaaa@3E94@ of node_ID in the global coordinate system.
VRi(node_ID) Rotational velocity i ∈ X , Y , Z MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfaaiaawUha caGL9baaaaa@3E94@ of node_ID in the global coordinate system.
ARi(node_ID) Rotational acceleration i ∈ X , Y , Z MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfaaiaawUha caGL9baaaaa@3E94@ of node_ID in the global coordinate system.
DRi(node_ID) Rotation i ∈ X , Y , Z MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfaaiaawUha caGL9baaaaa@3E94@ of node_ID in the global coordinate system.
Table 3. Shell or Solid Element Variables (same key as /H3D/SHELL or /H3D/SOLID)
key Definition
ALPHA(elem_ID) Shear angle alpha of material /MAT/LAW58 in degrees for the element elem_ID.
AMS(elem_ID) Elements using AMS timestep due to /DT/CST_AMS for the element elem_ID.
BFRAC(elem_ID) Burn fraction of the element elem_ID.
BULK(elem_ID) Artificial viscosity of the element elem_ID.
COLOR(elem_ID) Volume fraction color of the element elem_ID.
DAMielem_ID) Principal damage values in local cracking skew direction i ∈ 1 , 2 , 3 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaaGymaiaacYcacaaIYaGaaiilaiaaiodaaiaawUha caGL9baaaaa@3E2E@ for the element elem_ID.
DAMA(elem_ID) Maximum damage over time of all /FAIL criteria for the element elem_ID.
DAMG(elem_ID) Mean damage over thickness integration points (only for coupled damage models) for the element elem_ID.
DAMINI(elem_ID) Maximum damage initiation variable among all failure criteria using initiation variable before computing stress softening (/FAIL/INIEVO) for the element elem_ID.
DENS(elem_ID) Density for the element elem_ID.
DOMAIN(elem_ID) SPMD domain number of an element for the element elem_ID.
DT(elem_ID) Element timestep for the element elem_ID.
EINT(elem_ID) Element internal energy per unit volume for the element elem_ID.
EINTM(elem_ID) Specific internal energy for the element elem_ID.
EINTV(elem_ID) Internal energy density for the element elem_ID.
ENER(elem_ID) Specific energy density (internal energy divided by the element mass) for the element elem_ID.
ENTH(elem_ID) Enthalpy for the element elem_ID.
ENTHM(elem_ID) Massic enthalpy for the element elem_ID.
ENTHV(elem_ID) Enthalpy density for the element elem_ID.
EPSD(elem_ID) Equivalent strain rate for the element elem_ID.
EPSP(elem_ID) Plastic strain for the element elem_ID.
FAIL(elem_ID) Number of failed layers for the element elem_ID.
FAILURE(elem_ID) Damage of a specific failure criterion references by its optional identifier fail_ID for the element elem_ID.
FILL(elem_ID) Filling percentage for the element elem_ID.
FLDF(elem_ID) FLD damage factor indicator for the FLD failure model of the element elem_ID.
FLDZ(elem_ID) FLD failure zone factor for the FLD failure model of the element elem_ID.
GROUP(elem_ID) Internal group identifier of the element elem_ID.
HC_DSSE_F(elem_ID) HC_DSSE damage factor indicator of the element elem_ID.
HC_DSSE_Z(elem_ID) HC_DSSE failure zone factor for the HC_DSSE failure model of the element elem_ID.
HOURGLASS(elem_ID) Hourglass energy per mass unit of the element elem_ID.
K(elem_ID) Specific for turbulent energy in CFD of the element elem_ID.
MACH(elem_ID) Mach number of the element elem_ID.
MASS(elem_ID) Element mass of the element elem_ID
MOMi(elem_ID) Cell momentum Density in direction i ∈ X , Y , Z , X Y , Y Z , Z X MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfacaGGSaGa amiwaiaadMfacaGGSaGaamywaiaadQfacaGGSaGaamOwaiaadIfaai aawUhacaGL9baaaaa@45D8@ for FVM with Interface TYPE22 of the element elem_ID.
NL_EPSD(elem_ID) Non-local plastic strain rate of the element elem_ID.
NL_EPSP(elem_ID) Non-local plastic strain of the element elem_ID.
NXTF(elem_ID) Instability factor of /FAIL/NXT failure model of the element elem_ID.
OFF(elem_ID) Status of the element elem_ID.
P(elem_ID) Pressure of the element elem_ID.
PHI(elem_ID) Angle between the element system and direction 1 orthotropy of the element elem_ID.
SCHLIEREN(elem_ID) Schlieren image of the element elem_ID.
SIGEQ(elem_ID) Equivalent stress based on a material’s yield criteria of the element elem_ID.
SIGi(elem_ID) Stress i ∈ X , Y , Z , X Y , Y Z , Z X MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfacaGGSaGa amiwaiaadMfacaGGSaGaamywaiaadQfacaGGSaGaamOwaiaadIfaai aawUhacaGL9baaaaa@45D8@ in specified direction of the element elem_ID.
SSP(elem_ID) Sound speed of the element elem_ID.
TDEL(elem_ID) Time at which element elem_ID is deleted.
TDET(elem_ID) Detonation time of the element elem_ID.
TEMP(elem_ID) Temperature of the element elem_ID.
THICK(elem_ID) Thickness of the element elem_ID.
THIN(elem_ID) % thinning for shell of the element elem_ID.
TILLOTSON(elem_ID) Region identifier for Tillotson Equation of State of the element elem_ID.
TSAIWU(elem_ID) Tsai-Wu criterion for material of the element elem_ID.
TVIS(elem_ID) Specific for turbulent viscosity in CFD of the element elem_ID.
VDAMi(elem_ID) Value of damage i ∈ 1 , 2 , 3 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaaGymaiaacYcacaaIYaGaaiilaiaaiodaaiaawUha caGL9baaaaa@3E2E@ for /FAIL/SNCONNECT of the element elem_ID.
VELi(elem_ID) Cell velocity i ∈ X , Y , Z , X Y , Y Z , Z X MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfacaGGSaGa amiwaiaadMfacaGGSaGaamywaiaadQfacaGGSaGaamOwaiaadIfaai aawUhacaGL9baaaaa@45D8@ for FVM with Interface TYPE22 of the element elem_ID.
VFRAC1(elem_ID) Volumetric fraction i ∈ 1 , 2 , 3 , 4 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaaGymaiaacYcacaaIYaGaaiilaiaaiodacaGGSaGa aGinaaGaay5Eaiaaw2haaaaa@3F9C@ of the element elem_ID.
VOLU(elem_ID) Volume of the element elem_ID.
VONM(elem_ID) von Mises stress of the element elem_ID.
VORT(elem_ID) Vorticity resultant for ALE material of the element elem_ID.
VORTi(elem_ID) Vorticity in direction i ∈ X , Y , Z MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgI GiopaacmaabaGaamiwaiaacYcacaWGzbGaaiilaiaadQfaaiaawUha caGL9baaaaa@3E94@ for ALE material of the element elem_ID.
The Python script can get information from other sensors using the dictionary sensors and the following syntax:
  • sensors[sens_ID].get(key)
  • sensors[sens_ID][key]
Sensor Sensors Dictionary Keys
/SENSOR/DIST 'type', 'status', 'Distance'
/SENSOR/DIST_SURF 'type', 'status', 'Distance'
/SENSOR/ENERGY 'type', 'status', 'Eint', 'Ekin'
/SENSOR/GAUGE 'type', 'status', 'Pressure'
/SENSOR/INTER 'type', 'status', 'Force'
/SENSOR/RWALL 'type', 'status', 'Force'
Other sensors 'type', 'status'
Example (Using TIME)
Using global TIME:
/SENSOR/PYTHON/1
def sensor_1(arg):
    if TIME >= 0.001:
        return 1.0
    return 0.0
Example (Nodal)
Using nodal information:
/SENSOR/PYTHON/2
def sensor_2(arg):
    wall_disp=DX(30517)
    if wall_disp < -20.0:
        return 1.0
    return 0.0
Example (/SENSOR)
Using sensor information:
/SENSOR/PYTHON/3
def sensor_3(arg):
    Internal_energy = sensors[4]['Eint']
    if Internal_energy > 1E+07:
        return 1.0
    return 0.0
  1. The empty line after the “return” is mandatory.
  2. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  3. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N shell with /ACTIV
  4. The number of lines in a function is limited to 1000. But it is possible to break a function into multiple functions, since it is possible to call a Python function from another Python function.
  5. Radioss variables are in “read only” mode from Python.
  6. Python values will always be in double precision.
  7. The returned value will be 0.0 if the result has no data for the requested Radioss variable and element ELEM_ID.
  8. Radioss uses the Python library available in the HyperWorks installation. It is possible to use a different Python distribution by setting the environment variable RAD_PYTHON_PATH.
  9. The option “-python” must be added to the Starter command line to confirm that the user wants to explicitly use a Python script with Radioss.
