*SECTION_TSHELL
LS-DYNA Input Interface KeywordDefines the finite element properties of thick shell elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SECTION_TSHELL | |||||||
| sec_ID | ELFORM | NIP | |||||
Definition
| sec_ID | Section identifier. (Integer) |
| ELFORM | Solid element formulation options.
(Integer) |
| NIP | Number of integration points through the
thickness. (Integer) |
- This keyword maps to /PROP/TYPE20 (TSHELL), /PROP/TYPE21 (TSH_ORTH) or /PROP/TYPE22 (TSH_COMP).
- Depending on the element formulation and material used, the additional recommended solid properties are automatically defined.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
