*PART_SENSOR
LS-DYNA Input Interface KeywordDefine a sensor (*ELEMENT_SEATBELT_SENSOR) to activate or deactivate a discrete beam element part.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *PART_SENSOR | |||||||
| part_ID | SID | ACTIVE | |||||
Definition
| part_ID | Part identifier.
(Integer) |
| SID | Sensor
identifier. (Integer) |
| ACTIVE | Sensor flag.
(Integer) |
- The sensor identifier sens_ID and its behavior (ACTIVE) is mapped to the corresponding spring property /PROP/TYPE23 (SPR_MAT).
