/FAIL/LEMAITRE
Block Format Keyword A stress triaxiality-based failure model dedicated to ductile failure. It is based on plastic strain evolution, and the computed damage variable generates a softening of the stress tensor.
This failure model can be used for shell and solid elements and is compatible with all elasto-plastic materials.
/FAIL/LEMAITRE/mat_ID/unit_ID
ε D MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadseaaeqaaaaa@3893@ S D MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa aaleaacaWGebaabeaaaaa@37C4@ D C MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa aaleaacaWGebaabeaaaaa@37C4@ FAILIP P_thickfail
Optional line:
fail_ID
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
ε D MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadseaaeqaaaaa@3893@ Plastic strain value triggering the damage evolution.
Default = 1.0E30 (Real)
S D MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa aaleaacaWGebaabeaaaaa@37C4@ Strain energy release rate.
[ Pa ]
D C MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa aaleaacaWGebaabeaaaaa@37C4@ Critical damage value to trigger element deletion.
Default = 1.0 (Real)
FAILIP Number of failed integration points prior to solid element deletion.
Default = 1
P_thickfail Fraction of failed thickness for shell element deletion.
-1.0 ≤ P_thickfail ≤ 0
Fraction of failed integration point through thickness.
0.0 ≤ P_thickfail ≤ 1.0
Fraction of failed thickness.
fail_ID (Optional) Failure criteria identifier.
#RADIOSS STARTER
/UNIT/1
                  Mg                  mm                   s
/FAIL/LEMAITRE/25
#              EPS_D                 S_D                  DC              FAILIP         Pthick_fail
                 .27                0.05                  1.                   1                 0.5
#  fail_ID
      1234
  1. The LEMAITRE failure criterion is based on the damage coupled model proposed by Lemaitre & Chaboche and later Lemaitre & Desmorat. It considers the continuum damage mechanics framework introduced by Kachanov. To describe this framework let us consider a Representative Volume Elementary (RVE) of a section S MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36D0@ to which a normal load F MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36D0@ is applied.
    The stress in the undamaged volume (a) is then:
    σ = F S MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4WdmNaey ypa0ZaaSaaaeaacaWGgbaabaGaam4uaaaaaaa@3A74@
    If the same elementary volume is damaged (b), the remaining effective surface S ˜ MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabm4uayaaia aaaa@36DF@ decreases and the damaged surface S d a m MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa aaleaacaWGKbGaamyyaiaad2gaaeqaaaaa@39BD@ occupied by cavities increases. The damage variable is then defined as the ratio between the damaged and the initially sound surface.
    D = S d a m S MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9maalaaabaGaam4uamaaBaaaleaacaWGKbGaamyyaiaad2gaaeqa aaGcbaGaam4uaaaaaaa@3C7E@
    This variable evolves between 0 (no damage) and 1 for a complete RVE failure. In this case, the cavities are occupying the entire initial section of the elementary volume. The stress in the damaged volume can be expressed by:
    σ ˜ = F S ˜ = F S 1 − D = σ 1 − D MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbaG aacqGH9aqpdaWcaaqaaiaadAeaaeaaceWGtbGbaGaaaaGaeyypa0Za aSaaaeaacaWGgbaabaGaam4uamaabmaabaGaaGymaiabgkHiTiaads eaaiaawIcacaGLPaaaaaGaeyypa0ZaaSaaaeaacqaHdpWCaeaadaqa daqaaiaaigdacqGHsislcaWGebaacaGLOaGaayzkaaaaaaaa@4818@
    One can then differentiate the effective stress of the elasto-plastic section denoted σ ˜ MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbaG aaaaa@37CA@ and the equivalent damaged stress of the entire finite element section denoted σ = σ ˜ 1 − D = 1 − D E ε MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4WdmNaey ypa0Jafq4WdmNbaGaadaqadaqaaiaaigdacqGHsislcaWGebaacaGL OaGaayzkaaGaeyypa0ZaaeWaaeaacaaIXaGaeyOeI0IaamiraaGaay jkaiaawMcaaiaadweacqaH1oqzaaa@45FE@ . The stress in the element then decreases as the damage variable increases, until complete failure, in which the cavities occupy the entire element section ( D = 1 MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9iaaigdaaaa@3882@ ).
  2. The proposed LEMAITRE damage model considers an evolution of the damage variable governed by:
    Δ D = Y S D 1 − D Δ ε p if  ε p > ε D  and  σ 1 > 0 0 otherwise MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuiLdqKaam iraiabg2da9maaceaabaqbaeqabiGaaaqaamaalaaabaGaamywaaqa aiaadofadaWgaaWcbaGaamiraaqabaGcdaqadaqaaiaaigdacqGHsi slcaWGebaacaGLOaGaayzkaaaaaiabfs5aejabew7aLnaaBaaaleaa caWGWbaabeaaaOqaaiaabMgacaqGMbGaaeiiaiabew7aLnaaBaaale aacaWGWbaabeaakiabg6da+iabew7aLnaaBaaaleaacaWGebaabeaa kiaabccacaqGHbGaaeOBaiaabsgacaqGGaGaeq4Wdm3aaSbaaSqaai aaigdaaeqaaOGaeyOpa4JaaGimaaqaaiaaicdaaeaacaqGVbGaaeiD aiaabIgacaqGLbGaaeOCaiaabEhacaqGPbGaae4Caiaabwgaaaaaca GL7baaaaa@5FEC@
    Where, Y MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamywaaaa@36D5@ is a variable based on thermodynamic theory so-called elastic energy release rate, computed with:
    Y= 1 2 σ ˜ : C e −1 : σ ˜ = 1 2 σ 1−D : C e −1 : σ 1−D MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamywaiabg2 da9maalaaabaGaaGymaaqaaiaaikdaaaGabC4WdyaaiaGaaiOoaiaa doeadaqhaaWcbaGaamyzaaqaaiabgkHiTiaaigdaaaGccaGG6aGabC 4WdyaaiaGaeyypa0ZaaSaaaeaacaaIXaaabaGaaGOmaaaadaWcaaqa aiaaho8aaeaadaqadaqaaiaaigdacqGHsislcaWGebaacaGLOaGaay zkaaaaaiaacQdacaWGdbWaa0baaSqaaiaadwgaaeaacqGHsislcaaI XaaaaOGaaiOoamaalaaabaGaaC4WdaqaamaabmaabaGaaGymaiabgk HiTiaadseaaiaawIcacaGLPaaaaaaaaa@5377@
    Using some assumptions, this variable can be rewritten as:
    Y = σ ˜ V M R v 2 E MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamywaiabg2 da9maalaaabaGafq4WdmNbaGaadaWgaaWcbaGaamOvaiaad2eaaeqa aOGaamOuamaaBaaaleaacaWG2baabeaaaOqaaiaaikdacaWGfbaaaa aa@3F2E@
    Where,
    σ ˜ V M MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbaG aadaWgaaWcbaGaamOvaiaad2eaaeqaaaaa@39A2@
    Effective von Mises stress
    E MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyraaaa@36C1@
    Material Young's modulus
    R v MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaWG2baabeaaaaa@37F5@
    Stress triaxiality dependent coefficient that is obtained with:
    R v = 2 3 1 + ν + 3 1 − 2 ν η 2 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaWG2baabeaakiabg2da9maalaaabaGaaGOmaaqaaiaaioda aaWaaeWaaeaacaaIXaGaey4kaSIaeqyVd4gacaGLOaGaayzkaaGaey 4kaSIaaG4mamaabmaabaGaaGymaiabgkHiTiaaikdacqaH9oGBaiaa wIcacaGLPaaacqaH3oaAdaahaaWcbeqaaiaaikdaaaaaaa@4945@
    Where,
    ν MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AF@
    Poisson ratio
    η MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4TdGgaaa@37A3@
    Stress triaxiality
    According to this equation, you can see that the damage rate is higher at large stress triaxiality, implying a less ductile behavior with the increasing triaxiality.
    It is worth noting that the damage variable only evolves under tensile loading condition ( σ 1 > 0 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaaigdaaeqaaOGaeyOpa4JaaGimaaaa@3A6D@ ), as ductile fracture under compression is less likely.
  3. This failure model has three parameters to be set up:
    Plastic strain value threshold to trigger the damage variable evolution
    Fracture elastic energy release rate. If an accurate identification of this parameter is not performed, it is recommended to use R e 200 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSGaaeaaca WGsbWaaSbaaSqaaiaadwgaaeqaaaGcbaGaaGOmaiaaicdacaaIWaaa aaaa@3A30@ with R e MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaWGLbaabeaaaaa@37E4@ the initial yield stress.
    The critical damage value at which element / integration point is deleted, and stress tensor is set to zero (even if the evolution of the damage variable has not been completed).
  4. This damage model is compatible with /NONLOCAL/MAT to obtain regularized and mesh independent results.
  5. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value is output for failure model variables in the /INIBRI/FAIL (written in the .sta file with /STATE/BRICK/FAIL option). It can also be used for some specific failure output /H3D/ELEM/FAILURE.
1 Lemaitre, J., & Chaboche, J.-L. (1992). Mechanics of Solid Materials. Cambridge University Press
2 Lemaitre, J., & Desmorat, R. (2005). Engineering Damage Mechanics: Ductile, Creep, Fatigue and Brittle Failures. Springer
3 Kachanov, L. M. (1958). Time of the rupture process under creep conditions. Izvestiya Akademii Nauk SSSR, Otdelenie Tekhnicheskikh Nauk, 8, 26–31
