/FAIL/COMPOSITE
Block Format Keyword Describes simple failure model composite materials with composite fabric lamina defined in the plane 12.
This criterion is available for solids and shells elements. The composite fabric lamina is supposed to be defined in the plane 12.
| /FAIL/COMPOSITE/mat_ID/unit_ID | |||||||||
| Sig_11_T | Sig_11_C | Sig_22_T | Sig_22_C | Sig_12 | |||||
| Sig_33_T | Sig_33_C | Sig_23 | Sig_31 | ||||||
| n | Ifail_sh | Ifail_so | |||||||
| fail_ID |
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| Sig_11_T | Critical tensile stress in material
direction 1. Default = 1020 (Real) |
| Sig_11_C | Critical compression stress in
material direction 1. Default = 1020 (Real) |
| Sig_22_T | Critical tensile stress in material
direction 2. Default = 1020 (Real) |
| Sig_22_C | Critical compression stress in
material direction 2. Default = 1020 (Real) |
| Sig_12 | Critical shear stress in material
plane 12. Default = 1020 (Real) |
| Sig_33_T | Critical tensile stress in material
direction 3. Default = 1020 (Real) |
| Sig_33_C | Critical compression stress in
material direction 3. Default = 1020 (Real) |
| Sig_23 | Critical shear stress in material
plane 23. Default = 1020 (Real) |
| Sig_31 | Critical shear stress in material
plane 31. Default = 1020 (Real) |
| Shear scaling factor. Default = 0.0 (Real) |
| Dynamic time relaxation. Default = 1020 (Real) |
| n | Exponent. Default = 1.0 (Real) |
| Ifail_sh | Shell failure model flag.
(Integer) |
| Ifail_so | Solid failure model flag.
(Integer) |
| fail_ID | (Optional) Failure criteria
Example (Composite)
#RADIOSS STARTER
/UNIT/1
Unit system
Mg mm s
/MAT/COMPSH/1/1
Composite
# RHO_I
1.5E-09
# E11 E22 NU12 Iform E33
15000.0 15000.0 0.1 1 15000.0
# G12 G23 G31 EPS_f1 EPS_f2
5000.0 1000.0 1000.0 0.0 0.0
# EPS_t1 EPS_m1 EPS_t2 EPS_m2 dmax
0.05 0.1 0.05 0.1 0.0
# Wpmax Wpref Ioff WP_fail ratio
500.0 0.0 6 0 0.0
# c EPS_rate_0 alpha ICC_global
0.0 0.0 0.0 0
# sig_1yt b_1t n_1t sig_1maxt c_1t
200.0 0.0 0.0 0.0 0.0
# EPS_1t1 EPS_2t1 SIGMA_rst1 Wpmax_t1
0.02 0.04 50.0 0.0
# sig_2yt b_2t n_2t sig_2maxt c_2t
200.0 0.0 1.0 0.0 0.0
# EPS_1t2 EPS_2t2 sig_rst2 Wpmax_t2
0.02 0.04 50.0 0.0
# sig_1yc b_1c n_1c sig_1maxc c_1c
400.0 0.0 0.0 0.0 0.0
# EPS_1c1 EPS_2c1 sig_rsc1 Wpmax_c1
0.02 0.04 70.0 0.0
# sig_2yc b_2c n_2c sig_2maxc c_2c
# EPS_1c2 EPS_2c2 sig_rsc2 Wpmax_c2
0.02 0.04 70.0 0.0
# sig_12yt b_12t n_12t sig_12maxt c_12t
50.0 0.0 0.0 0.0 0.0
# EPS_1t12 EPS_2t12 sig_rst12 Wpmax_t12
0.0 0.0 0.0 0.0
# GAMMA_ini GAMMA_max d3max
0.0 0.0 0.0
# Fsmooth Fcut
0 0.0
/FAIL/COMPOSITE/1/1
# SIG_11_T SIG_11_C SIG_22_T SIG_22_C SIG_12
200.0 400.0 200.0 400.0 50.0
# SIG_33_T SIG_33_C SIG_23 SIG_31
50.0 50.0 50.0 50.0
# BETA TAU_MAX EXP_N IFAIL_SH IFAIL_SO
0.1 0.0 0.0 0 0
# FAIL_ID
1
#ENDDATA
- The failure modes are defined for shell and solid elements:
- Mode 1: tensile in direction 1
- Mode 2: compression in direction 1
- Mode 3: tensile in direction 2
- Mode 4: compression in direction 2
- Mode 5: shear in direction 12
- The failure modes are defined for solid elements only:
- Mode 6: tensile in direction 3
- Mode 7: compression in direction 3
- Mode 8: shear in direction 23
- Mode 9: shear in direction 31
- The damage value is defined as:
Failure is reached when . This damage value shows with /ANIM/SHELL/DAMA.
- When damage is reached and if Ifail_sh or
Ifail_so are greater than 0, the stresses are
decreased by using an exponential function to avoid numerical instabilities.
A relaxation technique is used by decreasing the stress
gradually.
With, and .
Where,- Time.
- Start time of relaxation when the damage criteria is assumed.
- Time of dynamic relaxation.
- Stress at the beginning of damage.
It is recommended to define larger than 10 simulation time steps.
- The fail_ID is used with /STATE/SHELL/FAIL and /INISHE/FAIL for shell. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/SHELL/FAIL for shell).
- The different failure modes can be plotted using the option /H3D/ELEM/FAILURE/ID=fail_ID with the option MODE (= I or ALL).
- A global failure index (which corresponds to the maximum between all modes) can be plotted using /H3D/ELEM/FAILURE/ID=fail_ID without the MODE option.
