*ELEMENT_SEATBELT_SENSOR
LS-DYNA Input Interface KeywordDefines a seat belt sensor.
(1) (2) (3) (4) (5) (6) (7) (8)
SID STYP
For STYP = 1: Acceleration sensor
Nod_ID DOF ACC ATIME
For STYP = 3: Time sensor
TIME
For STYP = 4: Displacement sensor
Node_ID1 Node_ID2 DMX DMN
Definition
SID Sensor identifier.
(Integer)
STYP Sensor type.
= 1
Node acceleration sensor.
Sensor is activated when acceleration of the node Nod_ID in the direction DOF exceeds defined value ACC during minimum time ATIME.
= 3
Time sensor.
Sensor is activated when TIME value is reached.
= 4
Displacement sensor.
Sensor is activated when the distance between nodes Node_ID1 and Node_ID2 is bigger than distance DMX or smaller than distance DMN.
(Integer)
Nod_ID Node.
(Integer)
DOF Accelerometer direction.
= 1 (Default)
Global X direction
= 2
Global Y direction
= 3
Global Z direction
(Integer)
ACC Minimum absolute value of acceleration.
(Real)
[ m s 2 ]
ATIME Minimum duration time which acceleration exceeds the limit.
(Real)
[ s ]
TIME Time sensor activation.
(Real)
[ s ]
Node_ID1 Displacement sensor node 1.
(Integer)
Node_ID2 Displacement sensor node 2.
(Integer)
DMX Minimum distance.
Default = -1E30 (Real)
[ m ]
DMN Maximum distance.
Default = 1E30 (Real)
[ m ]
  1. This keyword maps to:
