*ELEMENT_SEATBELT_RETRACTOR
LS-DYNA Input Interface KeywordDefines a 1D seat belt retractor element.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *ELEMENT_SEATBELT_RETRACTOR | |||||||
| RID | RNID | REID | SENS_ID1 | SENS_ID2 | SENS_ID3 | SENS_ID4 | |
| Tdelay | PULL | FCT_L | FCT_UL | FEED | |||
Definition
| RID | Retractor
identifier. (Integer) |
| RNID | Retractor node
| REID | Seat belt element identifier
attached to the retractor. (Integer) |
| SENS_ID1 | Sensor for retractor
activation. (Integer) |
| SENS_ID2 | Sensor for retractor
| SENS_ID3 | Sensor for retractor
| SENS_ID4 | Sensor for retractor
| Tdelay | Time delay. (Real) |
| PULL | Seat belt pull length for
locking. (Real) |
| FCT_L | Load curve
| FCT_UL | Unload curve
| FEED | Feed element
length. (Real) |
- This keyword maps to /RETRACTOR/SPRING.
- First non-zero sensor is used to activate pretensioner. Time delay Tdelay is added to the sensor activation.
