*DEFINE_HEX_SPOTWELD_ASSEMBLY_{OPTION}
LS-DYNA Input Interface KeywordDefine a cluster of connection solid elements for post-processing and failure control of the solid connection element.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DEFINE_HEX_SPOTWELD_ASSEMBLY_{OPTION} | |||||||
| ID_SW | |||||||
| Solid_ID1 | Solid_ID2 | Solid_ID3 | Solid_ID4 | Solid_ID5 | Solid_ID6 | Solid_ID7 | Solid_ID8 |
Definition
| OPTION |
| ID_SW | Cluster
identifier. (Integer) |
| Solid_IDi | Connection solid connection
identifier (up to 16). (Integer) |
- This keyword maps to /CLUSTER and /TH/CLUSTER.
