*DEFINE_CURVE_SMOOTH
LS-DYNA Input Interface KeywordDefines a simple smooth function, mainly used to impose a displacement on metal forming tool.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DEFINE_CURVE | |||||||
| Curve_ID | Area | Xstart | Xstop | Xrise | Ymax | ||
Definition
| Curve_ID | Curve
identifier. (Integer) |
| Area | Area under the
curve. (Real) |
| Xstart | Starting abscissa
value. (Real) |
| Xstop | Stop abscissa value.
(Real) |
| Xrise | Rise value from
Y=0 to
Y=Ymax. (Real) |
| Ymax | Maximum ordinate value.
(Real) |
- This keyword maps to /FUNCT_SMOOTH.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
