/ALE/GRID/VOLUME
Engine Keyword With this keyword it is possible to switch to smoothing formulation grid control is based on volume. Each ALE node position is computed as the average position of the centroids of the elements to which it is connected.
The volume of the elements is used to weigh the average positions.
/ALE/GRID/VOLUME
  1. For more details, refer to ALE Grid Calculation in the User Guide and /ALE/GRID/VOLUME in the Reference Guide.
  2. This option is not available when /ALE/GRID/ZERO is initially set in the model.
