/ALE/GRID/LAPLACIAN
Engine Keyword With this keyword it is possible to switch to Laplacian grid control or to change the parameters. ALE grid smoothing using the Laplacian smoothing method for 2D and 3D elements.
/ALE/GRID/LAPLACIAN
λ Niter
  1. For more details, refer to ALE Grid Calculation in the User Guide and /ALE/GRID/LAPLACIAN in the Reference Guide.
  2. This option is not available when /ALE/GRID/ZERO is initially set in the model.
