/ALE/GRID/LAGRANGE
Engine Keyword With this keyword it is possible to switch to Lagrangian framework (grid velocity set to material velocity). The material velocity is used to update the grid.
/ALE/GRID/LAGRANGE
- For more details, refer to ALE Grid Calculation in the User Guide and /ALE/GRID/LAGRANGE in the Reference Guide.
- This option is not available when /ALE/GRID/ZERO is initially set in the model.
