/ALE/GRID/FLOW-TRACKING
Engine Keyword With this keyword it is possible to switch to flow tracking grid control or to change the parameters. ALE mesh motion and deformation based on mass-weighted average velocity of the material flow inside the ALE mesh.
I_def scale_def
I_rot scale_rot
  1. For more details, refer to ALE Grid Calculation in the User Guide and /ALE/GRID/FLOW-TRACKING in the Reference Guide.
  2. This option is not available when /ALE/GRID/ZERO is initially set in the model.
