Since the experimental data (UFC charts) use the {cm, g, µs, Mbar} unit system, this
study is conducted using the same unit system.
The surface burst is characterized by a wave decomposed in two regions:
A Mach Front region, where the reflected and the incident waves overlap,
forming an assuming constant pressure planar wave,
A Free Air Burst region above the Mach Front.
In
Radioss , only the Mach Front region is implemented
along the vertical axis (shown in the animation below):
Figure 3 . House model
Here the scaled distance
Z
MathType@MTEF@5@5@+=
feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr
4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb
a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr
0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape
GaamOwaaaa@36EC@
(cm/g1/3 ) is introduced:
Z
R
W
1
3
GaamOwaiabg2da9maalaaapaqaa8qacaWGsbaapaqaa8qacaWGxbWd
amaaCaaaleqabaWdbmaalaaapaqaa8qacaaIXaaapaqaa8qacaaIZa
aaaaaaaaaaaa@3C05@
Where,
R
GaamOwaaaa@36EC@
Distance from the center of the detonation charge to the target
(cm)
W
GaamOwaaaa@36EC@
TNT-equivalent mass (g)
The scaled distance suggests that two charges with the same geometry, explosive
composition, and ambient conditions will generate self-similar blast waves when
their scaled distances match.
Figure 4 . Equivalence of blast wave
This allows the pressure to be computed from experimental data for a given charge (
W
GaamOwaaaa@36EC@
) and a given location (
R
GaamOwaaaa@36EC@
The equation used to compute the pressure in /LOAD/PBLAST is the
modified Friedlander equation:
P
t
P
e
b
t
t
a
t
1
t
t
a
t
Gaamiuamaabmaapaqaa8qacaWG0baacaGLOaGaayzkaaGaeyypa0Ja
amiua8aadaahaaWcbeqaa8qacqGHRaWkaaGccaGGUaGaamyza8aada
ahaaWcbeqaa8qacqGHsislcaWGIbGaaiOlamaalaaapaqaa8qacaWG
0bGaeyOeI0IaamiDa8aadaWgaaadbaWdbiaadggaa8aabeaaaSqaa8
qacaWG0bWdamaaCaaameqabaWdbiabgUcaRaaaaaaaaOWaaeWaa8aa
baWdbiaaigdacqGHsisldaWcaaWdaeaapeGaamiDaiabgkHiTiaads
hapaWaaSbaaSqaa8qacaWGHbaapaqabaaakeaapeGaamiDa8aadaah
aaWcbeqaa8qacqGHRaWkaaaaaaGccaGLOaGaayzkaaaaaa@5189@
The profile of the modified Friedlander equation at a given location is:
Figure 5 . Friedlander pressure profile
Where,
I
Gaamysa8aadaWgaaWcbaWdbiabgglaXcWdaeqaaaaa@3923@
The impulses (integral of pressure with respect to time on the interval
of time
t
GaamiDa8aadaahaaWcbeqaa8qacqGHRaWkaaaaaa@3834@
t
a
GaamiDa8aadaWgaaWcbaWdbiaadggaa8aabeaaaaa@3846@
The propagation time of the blast wave from the charge to the
target
In
Radioss , the negative phase is ignored and
P
0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOaeaaaaaaaaa8qaba
GaamiuamaaCaaaleqabaGaeyOeI0caaaaa@37FC@
is replaced by a
P
m
i
n
Gaamiua8aadaWgaaWcbaWdbiaad2gacaWGPbGaamOBaaWdaeqaaaaa @3A0F@
value (defaults to 10
-20 ). In this case
and until the end of this study, the pressure is only described by:
P
m
a
x
@3A0F@
which replaces
P
GaamiuamaaCaaaleqabaGaey4kaScaaaaa@37F1@
d
t
0
GaamizaiaadshapaWaaSbaaSqaa8qacaaIWaaapaqabaaaaa@3903@
which replaces
t
P
m
i
n
@3A0F@
which replaces
P
t
GaamysamaaCaaaleqabaGaeyOeI0caaaaa@37F5@
and
I
Gaamysa8aadaWgaaWcbaWdbiabgkHiTaWdaeqaaaaa@3822@
vanish.
t
a
is still the same
Figure 6 . Blast wave pressure profile implemented in Radioss
The blast pressure computed in
/LOAD/PBLAST for
Exp_data =
3 is fitted using experimental
data (UFC charts) which are determined by:
H
c
Gaamisa8aadaWgaaWcbaWdbiaadogaa8aabeaaaaa@381C@
Height of the charge
R
g
Ground distance between the target and the charge
H
s
Height of the target
H
t
Height of the triple point and of course
W
0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaiaadEfaaaa@36C9@
From
H
c
R
g
Z
c
and
Z
g
can be computed and used to obtain
Z
t
and
Z
g
in the first chart:
Figure 7 . Blast wave pressure profile implemented in Radioss
Since there is only a limited number of curves for values of
Z
c
an interpolation is required.
In general, the interpolation looks like this:
Figure 8 . Interpolation schematic
Identify the two curves bounding (
f
k
1
f
k
1
GaamOza8aadaWgaaWcbaWdbiaadUgacqGHRaWkcaaIXaaapaqabaGc
peGaaiilaiaacckacaWGMbWdamaaBaaaleaapeGaam4AaiabgkHiTi
aaigdaa8aabeaaaaa@3FAA@
On each bounding curve, identify the closest value above and under on the
abscissa (
x
k
1
f
k
1
x
k
1
f
k
1
x
k
1
f
k
1
x
k
1
f
k
1
WaaqGaa8aabaWdbiaadIhapaWaaSbaaSqaa8qacaWGRbGaey4kaSIa
aGymaaWdaeqaaaGcpeGaayjcSdWdamaaBaaaleaapeGaamOza8aada
WgaaadbaWdbiaadUgacqGHsislcaaIXaaapaqabaaaleqaaOWdbiaa
cYcadaabcaWdaeaapeGaaGjbVlaadIhapaWaaSbaaSqaa8qacaWGRb
GaeyOeI0IaaGymaaWdaeqaaaGcpeGaayjcSdWdamaaBaaaleaapeGa
amOza8aadaWgaaadbaWdbiaadUgacqGHsislcaaIXaaapaqabaaale
qaaOWdbiaacYcacaaMe8+aaqGaa8aabaWdbiaadIhapaWaaSbaaSqa
a8qacaWGRbGaey4kaSIaaGymaaWdaeqaaaGcpeGaayjcSdWdamaaBa
aaleaapeGaamOza8aadaWgaaadbaWdbiaadUgacqGHRaWkcaaIXaaa
paqabaaaleqaaOWdbiaacYcacaaMe8+aaqGaa8aabaWdbiaadIhapa
WaaSbaaSqaa8qacaWGRbGaeyOeI0IaaGymaaWdaeqaaaGcpeGaayjc
SdWdamaaBaaaleaapeGaamOza8aadaWgaaadbaWdbiaadUgacqGHRa
WkcaaIXaaapaqabaaaleqaaaaa@64AE@
For every value
x
k
1
f
k
1
WaaqGaa8aabaWdbiaadIhapaWaaSbaaSqaa8qacaWGRbGaeyySaeRa
WgaaadbaWdbiaadUgacqGHXcqScaaIXaaapaqabaaaleqaaaaa@4201@
found previously, identity the corresponding
value on the ordinate (
y
k
1
f
k
1
y
k
1
f
k
1
y
k
1
f
k
1
y
k
1
f
k
1
WaaqGaa8aabaWdbiaadMhapaWaaSbaaSqaa8qacaWGRbGaey4kaSIa
cYcadaabcaWdaeaapeGaamyEa8aadaWgaaWcbaWdbiaadUgacqGHsi
slcaaIXaaapaqabaaak8qacaGLiWoapaWaaSbaaSqaa8qacaWGMbWd
amaaBaaameaapeGaam4AaiabgkHiTiaaigdaa8aabeaaaSqabaGcpe
Gaaiilamaaeiaapaqaa8qacaWG5bWdamaaBaaaleaapeGaam4Aaiab
gUcaRiaaigdaa8aabeaaaOWdbiaawIa7a8aadaWgaaWcbaWdbiaadA
gapaWaaSbaaWqaa8qacaWGRbGaey4kaSIaaGymaaWdaeqaaaWcbeaa
k8qacaGGSaWaaqGaa8aabaWdbiaadMhapaWaaSbaaSqaa8qacaWGRb
amOza8aadaWgaaadbaWdbiaadUgacqGHRaWkcaaIXaaapaqabaaale
qaaaaa@600B@
Calculate the interpolation coefficient on the abscissa on both curves to
calculate the interpolate
y
f
k
1
GaamyEa8aadaWgaaWcbaWdbiaadAgapaWaaSbaaWqaa8qacaWGRbGa
eyySaeRaaGymaaWdaeqaaaWcbeaaaaa@3C40@
on the two bounding curves:
a
x
f
k
1
x
k
x
k
1
f
k
1
x
k
1
f
k
1
x
k
1
f
k
1
Gaamyya8aadaWgaaWcbaWdbmaaeiaapaqaa8qacaWG4baacaGLiWoa
paWaaSbaaWqaa8qacaWGMbWdamaaBaaabaWdbiaadUgacqGHRaWkca
aIXaaapaqabaaabeaaaSqabaGcpeGaeyypa0ZaaSaaa8aabaWdbiaa
dIhapaWaaSbaaSqaa8qacaWGRbaapaqabaGcpeGaeyOeI0YaaqGaa8
aabaWdbiaadIhapaWaaSbaaSqaa8qacaWGRbGaeyOeI0IaaGymaaWd
aeqaaaGcpeGaayjcSdWdamaaBaaaleaapeGaamOza8aadaWgaaadba
WdbiaadUgacqGHRaWkcaaIXaaapaqabaaaleqaaaGcbaWdbmaaeiaa
paqaa8qacaWG4bWdamaaBaaaleaapeGaam4AaiabgUcaRiaaigdaa8
aabeaaaOWdbiaawIa7a8aadaWgaaWcbaWdbiaadAgapaWaaSbaaWqa
a8qacaWGRbGaey4kaSIaaGymaaWdaeqaaaWcbeaak8qacqGHsislda
abcaWdaeaapeGaamiEa8aadaWgaaWcbaWdbiaadUgacqGHsislcaaI
Xaaapaqabaaak8qacaGLiWoapaWaaSbaaSqaa8qacaWGMbWdamaaBa
aameaapeGaam4AaiabgUcaRiaaigdaa8aabeaaaSqabaaaaaaa@6176@
a
x
f
k
1
x
k
x
k
1
f
k
1
x
k
1
f
k
1
x
k
1
f
k
1
paWaaSbaaWqaa8qacaWGMbWdamaaBaaabaWdbiaadUgacqGHsislca
WdbiaadUgacqGHsislcaaIXaaapaqabaaaleqaaaGcbaWdbmaaeiaa
a8qacaWGRbGaeyOeI0IaaGymaaWdaeqaaaWcbeaak8qacqGHsislda
aameaapeGaam4AaiabgkHiTiaaigdaa8aabeaaaSqabaaaaaaa@61A2@
y
f
k
1
10
1
a
x
f
k
1
log
y
k
1
f
k
1
a
x
f
k
1
log
y
k
1
f
k
1
ey4kaSIaaGymaaWdaeqaaaWcbeaak8qacqGH9aqpcaaIXaGaaGima8
aadaahaaWcbeqaa8qadaWadaWdaeaapeWaaeWaa8aabaWdbiaaigda
cqGHsislcaWGHbWdamaaBaaameaapeWaaqGaa8aabaWdbiaadIhaai
aawIa7a8aadaWgaaqaa8qacaWGMbWdamaaBaaabaWdbiaadUgacqGH
RaWkcaaIXaaapaqabaaabeaaaeqaaaWcpeGaayjkaiaawMcaaiaac6
caciGGSbGaai4BaiaacEgadaqadaWdaeaapeWaaqGaa8aabaWdbiaa
dMhapaWaaSbaaWqaa8qacaWGRbGaeyOeI0IaaGymaaWdaeqaaaWcpe
GaayjcSdWdamaaBaaameaapeGaamOza8aadaWgaaqaa8qacaWGRbGa
ey4kaSIaaGymaaWdaeqaaaqabaaal8qacaGLOaGaayzkaaGaey4kaS
Iaamyya8aadaWgaaadbaWdbmaaeiaapaqaa8qacaWG4baacaGLiWoa
paWaaSbaaeaapeGaamOza8aadaWgaaqaa8qacaWGRbGaey4kaSIaaG
ymaaWdaeqaaaqabaaabeaal8qacaGGUaGaaeiBaiaab+gacaqGNbWa
aeWaa8aabaWdbmaaeiaapaqaa8qacaWG5bWdamaaBaaameaapeGaam
4AaiabgUcaRiaaigdaa8aabeaaaSWdbiaawIa7a8aadaWgaaadbaWd
biaadAgapaWaaSbaaeaapeGaam4AaiabgUcaRiaaigdaa8aabeaaae
qaaaWcpeGaayjkaiaawMcaaaGaay5waiaaw2faaaaaaaa@7286@
y
f
k − 1
10
1 −
a
x
f
k − 1
. log
y
k − 1
f
k − 1
a
x
f
k − 1
. log
y
k + 1
f
k − 1
eyOeI0IaaGymaaWdaeqaaaWcbeaak8qacaGGGcGaeyypa0JaaGymai
aaicdapaWaaWbaaSqabeaapeWaamWaa8aabaWdbmaabmaapaqaa8qa
caaIXaGaeyOeI0Iaamyya8aadaWgaaadbaWdbmaaeiaapaqaa8qaca
WG4baacaGLiWoapaWaaSbaaeaapeGaamOza8aadaWgaaqaa8qacaWG
RbGaeyOeI0IaaGymaaWdaeqaaaqabaaabeaaaSWdbiaawIcacaGLPa
aacaGGUaGaciiBaiaac+gacaGGNbWaaeWaa8aabaWdbmaaeiaapaqa
a8qacaWG5bWdamaaBaaameaapeGaam4AaiabgkHiTiaaigdaa8aabe
aaaSWdbiaawIa7a8aadaWgaaadbaWdbiaadAgapaWaaSbaaeaapeGa
am4AaiabgkHiTiaaigdaa8aabeaaaeqaaaWcpeGaayjkaiaawMcaai
abgUcaRiaadggapaWaaSbaaWqaa8qadaabcaWdaeaapeGaamiEaaGa
ayjcSdWdamaaBaaabaWdbiaadAgapaWaaSbaaeaapeGaam4Aaiabgk
HiTiaaigdaa8aabeaaaeqaaaqabaWcpeGaaiOlaiaabYgacaqGVbGa
ae4zamaabmaapaqaa8qadaabcaWdaeaapeGaamyEa8aadaWgaaadba
WdbiaadUgacqGHRaWkcaaIXaaapaqabaaal8qacaGLiWoapaWaaSba
aWqaa8qacaWGMbWdamaaBaaabaWdbiaadUgacqGHsislcaaIXaaapa
qabaaabeaaaSWdbiaawIcacaGLPaaaaiaawUfacaGLDbaaaaaaaa@73E1@
f
to calculate the final interpolate
y
a
f
y
k
y
f
k
1
y
f
k
1
y
f
k
1
Gaamyya8aadaWgaaWcbaWdbiaadAgaa8aabeaak8qacqGH9aqpdaWc
aaWdaeaapeGaamyEa8aadaWgaaWcbaWdbiaadUgaa8aabeaak8qacq
GHsislcaWG5bWdamaaBaaaleaapeGaamOza8aadaWgaaadbaWdbiaa
dUgaa8aabeaal8qacqGHsislcaaIXaaapaqabaaakeaapeGaamyEa8
aadaWgaaWcbaWdbiaadAgapaWaaSbaaWqaa8qacaWGRbaapaqabaWc
peGaey4kaSIaaGymaaWdaeqaaOWdbiabgkHiTiaadMhapaWaaSbaaS
qaa8qacaWGMbWdamaaBaaameaapeGaam4AaaWdaeqaaSWdbiabgkHi
Tiaaigdaa8aabeaaaaaaaa@4DDF@
y
k
10
1 −
a
f
. log
y
f
k − 1
a
f
. log
y
f
k + 1
GaamyEa8aadaWgaaWcbaWdbiaadUgaa8aabeaak8qacqGH9aqpcaaI
XaGaaGima8aadaahaaWcbeqaa8qadaWadaWdaeaapeWaaeWaa8aaba
WdbiaaigdacqGHsislcaWGHbWdamaaBaaameaapeGaamOzaaWdaeqa
aaWcpeGaayjkaiaawMcaaiaac6caciGGSbGaai4BaiaacEgadaqada
WdaeaapeGaamyEa8aadaWgaaadbaWdbiaadAgapaWaaSbaaeaapeGa
abgUcaRiaadggapaWaaSbaaWqaa8qacaWGMbaapaqabaWcpeGaaiOl
aiGacYgacaGGVbGaai4zamaabmaapaqaa8qacaWG5bWdamaaBaaame
aapeGaamOza8aadaWgaaqaa8qacaWGRbGaey4kaSIaaGymaaWdaeqa
aaqabaaal8qacaGLOaGaayzkaaaacaGLBbGaayzxaaaaaaaa@5ABE@
Now, adapt
f
x
and
y
to interpolate any quantities. This
interpolation is done for
Z
t
P
r
α
Gaamiua8aadaWgaaWcbaWdbiaadkhapaWaaSbaaWqaa8qacqaHXoqy
a8aabeaaaSqabaaaaa@3A29@
and
I
r
α
After interpolation and determination of
Z
t
H
t
can be calculated.
If
H
s
H
t
Gaamisa8aadaWgaaWcbaWdbiaadohaa8aabeaak8qacqGH+aGpcaWG
ibWdamaaBaaaleaapeGaamiDaaWdaeqaaaaa@3B6E@
, the target is above the triple point and therefore
should be charged with Exp_data = 1 (Free Air
burst).
If
H
s
H
t
Gaamisa8aadaWgaaWcbaWdbiaadohaa8aabeaak8qacqGH8aapcaWG
ibWdamaaBaaaleaapeGaamiDaaWdaeqaaaaa@3B6A@
, the target will be charged with
Exp_data =
3 by the following quantities:
The incident wave referred to as the “side on” wave (abbreviation: so),
P
s
o
Gaamiua8aadaWgaaWcbaWdbiaadohacaWGVbaapaqabaaaaa@3928@
and
P
r
α
, where the captor/surface normal is
perpendicular to the blast wave direction. This quantity is a function of
α
GaeqySdegaaa@37AC@
the angle between the normal of the ground
and the direction of detonation (Figure 1 ) with its corresponding impulse
I
s
o
or
I
r
α
The reflected wave where the captor/surface normal is parallel to the blast
wave direction and its corresponding impulse
I
r
The quantities are obtained in the following charts after calculating
α
tan
R
G
H
c
GaeqySdeMaeyypa0JaaeiDaiaabggacaqGUbWaaeWaa8aabaWdbmaa
laaapaqaa8qacaWGsbWdamaaBaaaleaapeGaam4raaWdaeqaaaGcba
WdbiaadIeapaWaaSbaaSqaa8qacaWGJbaapaqabaaaaaGcpeGaayjk
aiaawMcaaaaa@4195@
Figure 9 . Blast wave pressure profile implemented in Radioss
Figure 10 . Blast wave pressure profile implemented in Radioss
P
r
α
P
s
o
a8aabeaaaSqabaGcpeGaeyypa0Jaamiua8aadaWgaaWcbaWdbiaado
hacaWGVbaapaqabaGcpeGaaiilaaaa@3F2E@
the scaled distance
Z
is determined from the Exp_data =
1 (Free Air Burst) chart and used to find the corresponding
values for
P
r
and
t
a
Repeat the same process with:
i
r
α
i
s o
I
r
α
W
1
3
GaamyAa8aadaWgaaWcbaWdbiaadkhapaWaaSbaaWqaa8qacqaHXoqy
a8aabeaaaSqabaGcpeGaeyypa0JaamyAa8aadaWgaaWcbaWdbiaado
hacaWGVbaapaqabaGcpeGaeyypa0ZaaSaaa8aabaWdbiaadMeapaWa
aSbaaSqaa8qacaWGYbWdamaaBaaameaapeGaeqySdegapaqabaaale
qaaaGcbaWdbiaadEfapaWaaWbaaSqabeaapeWaaSaaa8aabaWdbiaa
igdaa8aabaWdbiaaiodaaaaaaaaaaaa@4702@
and find
i
r
I
r
W
1
3
GaamyAa8aadaWgaaWcbaWdbiaadkhaa8aabeaak8qacqGH9aqpdaWc
aaWdaeaapeGaamysa8aadaWgaaWcbaWdbiaadkhaa8aabeaaaOqaa8
qacaWGxbWdamaaCaaaleqabaWdbmaalaaapaqaa8qacaaIXaaapaqa
a8qacaaIZaaaaaaaaaaaaa@3EC2@
and
d
t
0
Figure 11 . Blast wave pressure profile implemented in Radioss
From these two quantities, the pressure applied to the surface also satisfies the
following:
P
b
l
a
s
t
t
cos
2
θ
P
r
t
1
cos
θ
2.
cos
2
θ
P
so
t
P
s
o
t
i
f
cos
θ
0
i
f
cos
θ
0
Gaamiua8aadaWgaaWcbaWdbiaadkgacaWGSbGaamyyaiaadohacaWG
0baapaqabaGcpeWaaeWaa8aabaWdbiaadshaaiaawIcacaGLPaaacq
GH9aqpdaGabaWdaeaafaqabeGabaaabaWdbiGacogacaGGVbGaai4C
a8aadaahaaWcbeqaa8qacaaIYaaaaOWaaeWaa8aabaWdbiabeI7aXb
GaayjkaiaawMcaaiaac6cacaqGqbWdamaaBaaaleaapeGaaeOCaaWd
aeqaaOWdbmaabmaapaqaa8qacaqG0baacaGLOaGaayzkaaGaey4kaS
YaaeWaa8aabaWdbiaaigdacqGHRaWkcaqGJbGaae4Baiaabohadaqa
daWdaeaapeGaeqiUdehacaGLOaGaayzkaaGaeyOeI0IaaGOmaiaac6
caciGGJbGaai4BaiaacohapaWaaWbaaSqabeaapeGaaGOmaaaakmaa
bmaapaqaa8qacqaH4oqCaiaawIcacaGLPaaaaiaawIcacaGLPaaaca
GGUaGaaeiua8aadaWgaaWcbaWdbiaabohacaqGVbaapaqabaGcpeWa
aeWaa8aabaWdbiaadshaaiaawIcacaGLPaaaa8aabaWdbiaadcfapa
WaaSbaaSqaa8qacaWGZbGaam4BaaWdaeqaaOWdbmaabmaapaqaa8qa
caWG0baacaGLOaGaayzkaaaaaaGaay5EaaWdauaabeqaceaaaeaape
GaamyAaiaadAgaciGGJbGaai4BaiaacohadaqadaWdaeaapeGaeqiU
dehacaGLOaGaayzkaaGaeyOpa4JaaGimaaWdaeaapeGaamyAaiaadA
gaciGGJbGaai4BaiaacohadaqadaWdaeaapeGaeqiUdehacaGLOaGa
ayzkaaGaeyizImQaaGimaaaaaaa@82BA@
Figure 12 . Angle
θ
schematic
Where,
θ
is the angle between the surface normal and the direction
of the detonation point.
From
Equation 10 :
If
θ
0
GaeqiUdeNaeyypa0JaaGimaaaa@3983@
P
r
Gaaeiua8aadaWgaaWcbaWdbiaabkhaa8aabeaaaaa@382F@
is obtained.
If
θ
π
2
GaeqiUdeNaeyyzIm7aaSaaa8aabaWdbiabec8aWbWdaeaapeGaaGOm
aaaaaaa@3C50@
or 90 degrees,
P
s
o
is obtained.
This corresponds to the measurement data obtained with the captors (UFC charts).
Previously,
I
was introduced as the integral of the pressure with
respect to time (positive or negative phase). The same process is applied to
P
r
and
P
s
o
, with the impulses denoted by
I
r
and
I
s
o
. In the charts,
i
r
and
i
s
o
are introduced as the impulse divided by
W
1
3
Gaam4va8aadaahaaWcbeqaa8qacaaIXaGaai4laiaaiodaaaaaaa@3960@
; the same applies to
d
t
0
and
t
a
Model Description
The boundary conditions are represented below:
Figure 13 . All boundary conditions applied to the shells for the
first three models
Figure 14 . All boundary conditions applied to the fourth
model
The two models are tested with 2D shell elements using the /PROP/TYPE1
(SHELL) property and the /MAT/LAW1 (ELASTIC)
material, with a rigid body attached. The elements are placed at distance of
R
GaamOwaaaa@36EC@
from the detonation point (
W
GaamOwaaaa@36EC@
is imposed).
Shell and material properties:
Properties
Value
Density
7.8 g/cm3
Young's modulus
2.1 Mbar
Poisson ratio
0.3
Thickness
1 cm
The first goal is to compare
P
r
P
s
o
I
r
I
s
o
, and
d
t
0
from the Radioss outputs
and the UFC charts. To achieve this,
W
GaamOwaaaa@36EC@
is imposed
W
500.10
3
g
feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9
vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x
fr=xb9adbeqaaeWaciGaaiaabeqaamaabaabbaGcbaWaaeWaaeaaca
WGxbGaeyypa0JaaGynaiaaicdacaaIWaGaaiOlaiaaigdacaaIWaWa
aWbaaSqabeaacaaIZaaaaOGaaGjbVlaadEgaaiaawIcacaGLPaaaaa a@412C@
and only
H
c
and
R
g
vary. The second goal is to evaluate Equation 10 for every 10 degrees from 0 degrees to 180 degrees for
different points of the list.
