OS-SL-T: 1030 Preloaded Modal Frequency Response Analysis
Tutorial Level: Intermediate This tutorial demonstrates how to solve a modal frequency response analysis for a Differential housing model by including the effect of pretension of bolts as preload.
- Set up the problem in SimLab
- Apply Loads and Boundary Conditions
- Solve the job
- View the results
- Plot graph
Launch SimLab
Import the Model
From the menu bar, click .
An Import File dialog opens.
- Select the Differential_Housing.gda file you saved to your working directory from the Differential_Housing.zip file.
Click Open.
The Differential_Housing.gda file is loaded into the current SimLab database.
Set Up Problem
Create Solid Bolds for Assembly
The Bolt Modeling Ribbon opens.
From the Bolt Modelling Ribbon, 3D
Bolt group, click the Create Bolt
tool.
The Create Solid Bolt dialog opens.
In the Create Solid Bolt dialog, enter the values as shown
below.
Figure 1. Bolt Parameters
For Washer face Input, select the disc faces of the Cover body in the modeling window.
Figure 2. Select Disc Faces of Cover Body for Washer Face
For Thread face Input, select the cylindrical faces of the carrier body in the
modeling window.
Figure 3. Select Cylindrical Faces of Carrier Body for Thread Face
For D2 based on D3, set the Shrinkage value to
0 and click OK.
Ten solid bolts are created.
In the Assembly tab of the Model Browser, select the 10
solid bolts, right-click in the modeling window, and
select Merge from the context menu.
In the Assembly tab of the Model Browser, the bolts are merged into a single bolt.
Merge the assemblies.
- In the Assembly tab of the Model Browser, select the Merged_Model.gda and Differential_Housing.gda assemblies.
- From Geometry ribbon, click the triangle next to the Model group label and select Merge Models from the context menu.
All bodies are merged under one assembly.
Create Solution
From the Solutions ribbon,
Physics group, click the
Structural tool and select
Coupled.
The Create Solution dialog opens.
In the Create Solution dialog, define the following
options:
Assign Property to Bodies
In this step you will assign the Cast Iron property for both the Carrier and Cover bodies and Steel property for the Bolts.
SimLab has default materials defined, so there is no need to define materials.
From the Analysis ribbon,
Property group, click the
Property tool.
The Analysis Property dialog opens.
- In the modeling window, select the Carrier body.
In the Analysis Property dialog, enter the values as shown
below and click Apply.
Figure 5. Carrier Body Property
Create a property for the Cover body.
- In the modeling window, select the Cover body.
- In the Analysis Property dialog, enter the values as shown below and click Apply.
Figure 6. Cover Body Property
Create a property for the Bolts.
- In the modeling window, select the Bolts.
- In the Analysis Property dialog, enter the values as shown below and click OK.
Figure 7. Bolts Property
The first loadcase is the non-linear static analysis where pretension is applied on the bolts and constraints are defined on the end of the carrier body. The second loadcase is the modal frequency response analysis in which a pressure load is applied on the inner face of the cover body and excitation load is created using the pressure load. The pretension effect of the bolts in the first loadcase is included in the second loadcase. Contacts are created between each part of the model.
Create Loadcase
In the Solutions tab of the Model Browser, right-click on
MFreq_with_Pretension and select Define
using Load case from the context menu.
LoadCase1 is created.
- Right-click on LoadCase1, select Rename from the context menu, and enter Pretension_Case.
- Under the Pretension_Case loadcase, right-click on Type: Linear Static and select from the context menu.
Create Pretension Load
From the Bolt Modeling Ribbon, 3D
Bolt group, click the Solid Pretension
tool.
The Create Solid Pretension dialog opens.
In the Create Solid Pretension dialog, enter the values as
shown below.
Figure 8. Create Solid Pretension for Bolts
- In the modeling window, select the bolts body and click OK in the Create Solid Pretension dialog.
Create Constraints
- From the Analysis ribbon, Loads and Constraints group, click the Constraints tool.
From the secondary tool set, select the Fixed
tool.
The Fixed Constraint dialog opens.
In the Fixed Constraint dialog, enter the values as shown
below.
Figure 9. Fixed Constraint
In the modeling window, select the cylindrical faces of
the Carrier body and click OK
in the Fixed Constraint dialog.
Figure 10. Select Fixed Constraint Faces
Define Loadcase Parameters
the Pretension_Case loadcase and select
Loadcase Parameters from the context menu.
The Loadcase Parameters dialog opens.
In the Loadcase Parameters dialog, enter the values as
Figure 11. Loadcase Parameters Non Linear Analysis
Define Frequency Response Analysis Loadcase
From the Solutions tab of the Model Browser,
right-click LoadCase and select Create
Loadcase from the context menu.
LoadCase2 is created with linear static analysis.
- Right-click on LoadCase2, select Rename from the context menu, and enter Preloaded_MFreq.
- Under the Preloaded_MFreq loadcase, right-click Type: Linear Static and select from the context menu.
Create Face Group for Pressure Load
Multiple faces must be selected to create a pressure load on the inner face of the cover body.
In the modeling window, select the face in the cover
body.
Figure 12. Select Face
Right-click in the modeling window and select
Select Adjacent Layers from the context menu.
The Select Adjacent Layers dialog opens.
In the Select Adjacent Layers dialog, enable the
Create group checkbox and enter the name as
Pressure Faces.
Figure 13. Create Group of Faces
In the modeling window, select the limit faces and
click Apply in the
Select Adjacent Layers dialog.
Figure 14. Select Limit Faces
Create Pressure Load
- From the Analysis ribbon, Loads and Constraints group, click the Loads tool.
From the secondary tool set, select the Pressure
tool.
The Pressure dialog opens.
In the Pressure dialog, enter the values as shown
below.
Figure 15. Pressure Load Input
- In the Group tab of the Model Browser, select the Pressure_Faces group and click OK in the Pressure dialog.
Create Excitation Load
From the secondary tool set, select the Excitation
tool.
The Excitation Load dialog opens.
In the Excitation Load dialog, click
Create next to Amplitude table.
The Create Table dialog opens.
In the Create Table dialog, select
Frequency-Amplitude as the Loading Typer, enter the
values as shown below, and click OK.
Figure 16. Define Amplitude Table for Excitation Load
In the Excitation Load dialog, enter the values as shown
below and click OK.
The Pressure_Load defined will automatically be set as the Excitation load.
Figure 17. Excitation Load Input
Add Fixed Constraint
Define Loadcase Parameter and Result Request
on the Preloaded_MFreq loadcase and select
Figure 18. Loadcase Parameters Frequency Response Analysis
Right-click on the Preloaded_MFreq loadcase and select
Result Request from the context menu.
The Result Request dialog opens.
In the Result Request dialog, enter the values as shown
below and click OK.
Figure 19. Result Requests for Frequency Response Analysis
Create Contacts
Constraints group, click the Contact
tool.
The Define Contact dialog opens.
Create Cover_Bolts contact.
- In the Define Contact dialog, enter the values as shown below.
- In the modeling window, select the Cover for the main body and select the Bolts for the secondary body.
- In the Define Contact dialog, click Apply.
Figure 20. Contact Between Cover and Bolts
Create Carrier_Bolts contact.
- In the modeling window, select the Carrier for the main body and select the Bolts for the secondary body.
Figure 21. Contact Between Carrier and Bolts
Create Cover_Carrier contact.
- In the modeling window, select the Cover for the main body and select the Carrier for the secondary body.
- In the Define Contact dialog, click OK.
This contact is created to prevent the overlapping of Carrier and Cover bodies.Figure 22. Contact Between Cover and Carrier
Solve and View Results
Solve the Solution
Interpret the Results
After the model setup has been successfully solved, the results are automatically appended to the input model.
In the Results panel, change the Load Case to view the
results of the Preloaded_MFreq loadcase.
The Simulation of Results panel lists all the frequencies for which the results are computed.
Figure 23. Change Loadcase
- Use the Results panel to change the result component.
Plot Graph
In this step you will plot a graph of resultant displacement at different frequencies of the Preloaded_MFreq subcase.
From the Results ribbon, Results
group, click the XY Plot tool.
The X Y Plot dialog opens.
In the X Y Plot dialog, change the Data type to
Loadcase/Frequency.
Figure 25. Change Data Type
For X Data, click Loadcase.
The Loadcase dialog opens.
In the Loadcase dialog, enable the checkbox for
Subcase2 (Preloaded_MFreq) and click
OK.
Figure 26. Select Subcase to Plot Graph
In the modeling window, select any node from the model
and click Plot in the X Y Plot
dialog.
Figure 27. Example Graph
