OS-V: 0730 Scordelis-Lo Roof
MacNeal-Harder Test The Scordelis-Lo Roof is a classical benchmark problem for shell elements. Analytical and experimental investigations were initially performed by Scordelis and Lo.
Model Files
Benchmark Model
The roof structure is supported on both ends and loaded by self weight of 90 pounds per square foot, with only one quadrant modeled. Six types of elements are used for this problem. They are tria-shell, quad-shell, and hexa-solid elements, each with 1st and 2nd order. Each element type was benchmarked with different mesh density to check the convergence. As the original study was related to concrete structure, Poisson's ratio is set to zero. The structure is curved and its solution will exhibit membrane and bending behavior. Target solution for the vertical deflection at the midpoint of the free edge is 0.3024.
Linear Static Analysis Results
| Number of Nodes - space per sides | |||||
| 2 | 4 | 6 | 8 | 10 | |
| QUAD4 | 1.487 | 1.082 | 1.035 | 1.020 | 1.013 |
| QUAD8 | 1.436 | 1.179 | 1.139 | 1.116 | 1.102 |
| TRI3 | 1.169 | 0.753 | 0.829 | 0.886 | 0.920 |
| TRI6 | 1.326 | 1.107 | 1.077 | 1.063 | 1.055 |
| HEX8 | 0.142 | 0.550 | 0.868 | 0.951 | 1.000 |
| HEX20 | 1.071 | 1.052 | 1.046 | 1.045 | 1.043 |
Reference
MacNeal, R.H., and Harder, R.L., A Proposed Standard Set of Problems to Test Finite Element Accuracy, Finite Elements in Analysis and Design, 1 (1985) 3-20.
