OS-E: 6015 Direct Transient Response Analysis
This examples demonstrates the Rotor Dynamics direct transient response analysis using two coaxial rotors.
Model Files
Before you begin, copy the file(s) used in this example to
your working directory.
Model Description
This example consists of two coaxial rotors modeled using 1D elements with mass added at
the center. The rotors are attached to the stators through Spring and Damper elements at
both the ends. Dynamic loading conditions are applied using unbalanced rotating load.
| FE Model | 1D Elements |
| Material | Material MAT1 | Rotor:
| Reference Guide Entries | Keywords | RGYRO, ROTORG, RSPINT, UNBALNC |
Results
