OS-V: 0010 Elliptic Membrane
Test No. LE1 The model is a thin plate of thickness 0.1m subjected to a uniform pressure for linear static analysis. OptiStruct examines the direct stress at the point on inside the ellipse on the x-axis.
Model Files
Before you begin, copy the file(s) used in this problem
to your working directory.
Benchmark Model
Second order Hexahedral, Penta, Tetra, Quad and Tria elements are used to create the coarse and fine mesh. A uniform outward pressure of 10 MPa is applied on the outer face. The pressure is converted to force and is applied to the nodes for Quad8 and Tria6 elements.
The material properties are:
- Material Properties
- Value
- Young's Modulus
- 210 x 103 MPa
- Poisson's Ratio
- 0.3
Linear Static Analysis Results
All results are normalized with the target value (92.7 MPa).
| Direct Stress at Point D (MPa) | Normalized with the Target Value | |
| Solid Hexahedral: | ||
| Hex8 coarse | 63.15 | 1.467933492 |
| Hex20 coarse | 87.46 | 1.059913103 |
| Hex8 fine | 79.8 | 1.161654135 |
| Hex20 fine | 91.01 | 1.018569388 |
| Solid Wedges: | ||
| Penta6 coarse | 48.68 | 1.904272802 |
| Penta15 coarse | 95.21 | 0.973637223 |
| Penta6 fine | 67.3 | 1.377414562 |
| Penta15 fine | 94.28 | 0.983241409 |
| Solid Tetrahedral: | ||
| Tetra4 coarse | 53.34 | 1.737907762 |
| Tetra10 coarse | 95.96 | 0.966027511 |
| Tetra4 fine | 66.56 | 1.392728365 |
| Tetra10 fine | 95.28 | 0.972921914 |
| Quad Shells: | ||
| Quad4 coarse | 61.83 | 1.499272198 |
| Quad8 coarse | 86.67 | 1.069574247 |
| Quad4 fine | 79.7 | 1.163111669 |
| Quad8 fine | 91.48 | 1.013336248 |
| Triangular Shells: | ||
| Tria3 coarse | 54.06 | 1.714761376 |
| Tria6 coarse | 97.07 | 0.954980942 |
| Tria3 fine | 74.21 | 1.249157795 |
| Tria6 fine | 96.64 | 0.959230132 |
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
