Method 2: PCB Cooling Channel using Inlet Pressure and Outlet Pressure
Launch HyperMesh
Launch HyperMesh.
In the New Session window, select HyperMesh from the list of tools.
For Profile, select OptiStruct.
Click Create Session.
Figure 1. Create New Session This loads the user profile, including the appropriate template, menus,
and functionalities of HyperMesh relevant for
generating models for OptiStruct.
Import the Model
On the menu bar, select File > Import > HyperMesh Model.
Navigate to and select PCB.hm.
Click Import.
Set Up the Model
Define Material 1
Note: If the model loads outside of the modeling window,
press F to fit to window.
In the Model Browser, right-click and select Create > Material.
For Name, enter material1.
For Card Image, select MAT1 from the drop-down
menu.
Enter the following material properties:
For E, enter 210000
For NU (Poisson's ratio), enter 0.3.
For RHO, enter 7.85e-09.
Select the MAT4 check box and enter the following
properties:
For K (thermal conductivity), enter 44.0
For CP, enter 460000000.
For RHO, enter 7.8e-09.
Click
Close.
Figure 2. Create Material 1
Define Material 2
For Name, enter material2.
menu.
For E, enter 210000
properties:
Select the DARCY check box and enter the following fluid
KAPPA, enter 0.1.
For MU, enter 1e-09.
For K, enter 0.598.
For CP, enter 4183000000.
For RHO, enter 1e-09.
Click
Close.
Figure 3. Create Material 2
Define Property 1
In the Model Browser, double-click on
Properties to open the Property Browser.
In the browser, select property1.
For Card Image, select PSHELL from the drop-down
menu.
For Material, select Unspecified > to open advanced selection.
In the dialog, select material2 from the list.
Click OK.
For T (thickness), enter 0.5.
Click Close.
Figure 4. Define Property 1
Define Property 2
In the Property Browser, select property2.
menu.
In the dialog, select material1 from the list.
Click OK.
Click Close.
Figure 5. Define Property 2
Assign a Property to a Component
Components to open the Component Browser.
In the browser, select auto3.
For Property, select Unspecified > to open advanced selection.
Select property1 from the list and click
OK.
For Material, material2 is auto-selected. If material2 is not selected,
you can choose it using advanced selection.Figure 6. Assign Property
Apply Loads and Boundary Conditions
Apply Heat Flux
From the menu bar select the
Analyze ribbon.
On the ribbon, select Heat Flux.
Figure 7. Select Heat Flux
For ELSETID click Unspecified > Create to create a SURF set.
Figure 8. Create Heat Flux Load
Choose elements of property2.
Set the Q0 field to 10.0.
Click OK and Close.
Create the Inlet Node Set
In the Model Browser, right-click and select Create > Set.
For name, enter inlet.
For Card Image, select SET_GRID from the drop-down
menu.
For Entities, select nodes 131 to 151 as shown in Figure 9.
Figure 9. Inlet Nodes Figure 10. Create Inlet Node Set
Create the Outlet Node Set
For name, enter outlet.
menu.
For Entities, select nodes 191 to 211 as shown in Figure 11.
Figure 11. Outlet Nodes Figure 12. Create Outlet Node Set
Assign Thermal Boundary Conditions
Analyze ribbon.
On the ribbon, select the Temp Loads tool.
Figure 13. Select Temperature Load Tool
From the dialog, click nodes > and select by set.
Select inlet (nodes 131 to 151).
For load types, select SPC.
For value, enter 0.0.
Click Create and Close.
Create Inlet Pressure and Outlet Pressure
In the Model Browser, right-click and select Create > Load.
For Type, select SPCP from the drop-down menu.
For GSETID, select Unspecified > to open advanced selection.
In the dialog, select inlet.
For D, enter 0.1001.
Figure 14. Create Inlet Pressure
Create a second load for outlet pressure.
menu.
In the dialog, select outlet.
For D, enter 0.1.
Figure 15. Create Outlet Pressure
Create a Subcase
In the Model Browser, right-click and select Create > Load Step.
For name, enter CPU loading.
For Analysis Type, select Heat Transfer (Steady State)
For the following selections, use Unspecified > to open advanced selection.
For SPC, specify auto1.
For LOAD, specify auto1.
For SPCP, specify auto1.
Figure 16. Create Load Step
Set Up the Optimization
Create the Topology Design Space
On the menu bar, select the
Optimize ribbon.
On the ribbon, select Topology.
Figure 17. Select Topology
For Name, enter designvar.
For Property Type, select PSHELL from the drop-down
menu.
From List of Properties, select Unspecified > to open advanced selection.
In the dialog, select property1.
Under Parameters, For Mindim, enter 5.0.
Figure 18. Create Design Variable
Create Responses
Optimize ribbon.
On the ribbon, select Responses.
Figure 19. Select Response
For Name, enter VOLFRAC.
For Response Type, select volumefrac from the drop-down
menu.
Figure 20. Create Optimization Response
Click Close.
Create a second response.
For Name, enter tcomp.
For Response Type, select thermal compliance
Click Close.
Create the Objective
Optimize ribbon.
On the ribbon, select Objectives.
Figure 21. Select Objectives
For Objective Type, select Minimize.
For Response Id, select Unspecified > to open advanced selection.
In the dialog, select tcomp.
For Loadstep Id, open advanced selection and choose CPU
loading.
Figure 22. Create Objective
Create Constraints
Optimize ribbon.
On the ribbon, select Constraints.
Figure 23. Select Constraints
For Name, enter volconst.
For Response, select Unspecified > to open advanced selection.
In the dialog, select VOLFRAC.
For Lower Options, select Lower Bound from the drop-down
menu.
In the Lower Bound text box, enter 0.8.
Figure 24. Create Optimization Constraints
Click Close.
Submit the Job
Run OptiStruct.
From the Analyze ribbon, click Run OptiStruct
Solver.
Figure 25. Select Run OptiStruct Solver
Select the directory where you want to write the OptiStruct model file.
For File name, enter PCB.
The .fem filename extension is the recommended extension
for Bulk Data Format input decks.
Click Save.
Click Export.
In the Altair Compute Console, click
Run.
If the job is successful, an "OptiStruct Job Completed" message appears
in the Compute Console Solver View Message Log. New results
files are in the directory where the model file was written. The
PCB.out file is a good
place to look for error messages that could help debug the input deck if any
errors are present.
View the Results
Open the results in HyperView.
HyperView, select Contour.
In the first drop-down menu, for Results Type, select Element
Densities (v).
Click Apply.
Figure 26. Contour Plot for Element Densities and Grid Temperatures
