OS-V: 0710 Curved Cantilever Beam
MacNeal-Harder Test This is a curved cantilever beam solved with solid and shell elements. A model is made with each element's type to investigate the effect of distorted elements with a high aspect ratio.
Model Files
Benchmark Model
Six types of elements are used for this problem. They are tria-shell, quad-shell, and hexa-solid elements, each with 1st and 2nd order. Two loading cases, in-plane bending and transverse bending, are used for each model. For both load cases, unit loads are applied in a consistent fashion over all of the nodes at the tip of the beam.
| Load Type | Component | Value |
| In-plane bending | UY | 0.08734 |
| Transverse bending | UZ | 0.5022 |
Linear Static Analysis Results
| In-plane Bending | Transverse Bending | |
| QUAD4 | 0.952 | 0.955 |
| QUAD8 | 1.015 | 0.984 |
| TRI3 | 0.025 | 0.950 |
| TRI6 | 1.005 | 0.961 |
| HEX8 | 0.880 | 0.820 |
| HEX20 | 1.009 | 0.946 |
Reference
MacNeal, R.H., and Harder, R.L., A Proposed Standard Set of Problems to Test Finite Element Accuracy, Finite Elements in Analysis and Design, 1 (1985) 3-20.
