XTITLE
I/O Options and Subcase Information Entry The XTITLE command can be used in the I/O Options section to define the x-axis label for XYPUNCH or XYPLOT output from a Random Response Analysis.
XTITLE = title
| Argument | Description |
| title | Character
                                    string. Default = blank  |
- XTITLE may not be continued onto the next line.
 - An XTITLE definition applies to all
                    plots defined after XTITLE until another definition of
                        XTITLE occurs. The following example would assign
X-A,Y-Aand the default plot title to the first plot, thenX-A,Y-B, andC-Ato the second plot.XTITLE = X-A YTITLE = Y-A XYPLOT (first plot definition) YTITLE = Y-B TCURVE = C-A XYPLOT (second plot definition)
