WEIGHTCHECK
Subcase Information Entry Used to give a report of the mass properties of entire model, including weight, mass moment of inertia and the center of mass.
WEIGHTCHECK(print,grid,set) = option
| Argument | Options | Description |
| <PRINT, NOPRINT> |
| grid | <GRID> Default = 0  |
| set | <G, N, F, A, All> | Selects the Degree Of Freedom (DOF) set(s):
| option | <YES, NO> |
- WEIGHTCHECK must be specified before the first SUBCASE. Mass matrices will be printed out for different GRID sets, namely, G, N, F and A.
 - WEIGHTCHECK for set N, F and A also gives the percentage change in the rigid body mass/weight with respect to G-Set.
 - If PARAM, UCORD is defined in the model, the values are printed out relative to the user-defined coordinate system.
