TSTEPE
Subcase Information Entry Can be used to select Explicit Time Step Parameters for Nonlinear Explicit Analysis.
Attention: Valid for Explicit
                    Analysis only
TSTEPE = option
TSTEPE = 24
| Argument | Options | Description |
| option | <SID> No default  |
- A TSTEPE entry is mandatory for Nonlinear Explicit Analysis, only if ANALYSIS=NLEXPL is not defined in the subcase. If ANALYSIS=NLEXPL is defined, then only TTERM is mandatory for Nonlinear Explicit Analysis and TSTEPE is optional. If ANALYSIS=NLEXPL is not defined, then both TTERM and TSTEPE are mandatory.
